Wavy cuts
Wavy cuts
I am getting a wavy line cut when the table cuts along the long axis. seems mostly when it initiates the cut, but I can see that the circle is got straight lines as well. I have made sure all the gears are tight on the motors ant that there is no slop in the gantry.
Working with a TM3 with water table separate from the actual CNC table. Hypertherm 65 using fine cut consumables.
Re: Wavy cuts
how is the torch mount could it be loose??
Re: Wavy cuts
I can't move the cassette back and forth. This is a bolt together table and I am wondering if that might be the issue?
Edit: does not seem to matter where it is on the table either. I thought if I did have movement in the table making the part near the corner might lessen the wobble, but it was the same.
- WyoGreen
Re: Wavy cuts
You don't suppose there are loose guide bearings or binding on the long axis? Maybe a little slop that shouldn't be there?
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Re: Wavy cuts
Loose table can cause that but if you have straight cutting slats the metal could be moving on the slats. Slats need to be stationary just another thing to check.
Re: Wavy cuts
Yeah, I am frustrated. checked all I know how and the problem is still there?
Picture of my table.
Re: Wavy cuts
noclinkers does it make waves when u cut a long the x an the y . or just one an .i had a problem on my router table were it bolted to the gantry
Re: Wavy cuts
My problem is on the long axis x/y only, seems to do fine otherwise. I have tightened every nut, bolt and set screw there is on the machine with no change. The CNC table is not bolted to the water table,TM said it was not necessary. The table has been flawless for a year this way until now?
- Gamelord
- 4.5 Star Member
Re: Wavy cuts
The water table shouldn't have anything to do with it. You have something loose or something is out-of-round. Check all your bearings, pull them off and see if there is something on them such as gunk or any other foreign object. You can also try putting a pen on the torch and drawing the image instead of cutting it. Just tun the cutter off (you may need to turn off the THC too.) If the pen is also wobbling then you can rule out the torch.
Torchmate CAD
Torchmate CAD
Re: Wavy cuts
were the rails bolt to the gantry put a straight edge ..u may have over tighten them ..
Re: Wavy cuts
were are u located some times a second pare of eyes would help
Re: Wavy cuts
I have checked all the bearings and taken them off and rotated them around the table. It seems as if all of them are rotating smoothly, but that was with no weight on them. I am a little bit confused about what else could drag.
I would appreciate a second set of eyes. I am in Hopland CA. My wife is an excellent cook...lol
Re: Wavy cuts
ok mabe not by me lol 3000 miles i see it looks like ur useing love joy coupling on the stepperradicalrescue wrote:were are u located some times a second pare of eyes would help
Re: Wavy cuts
Ah c'mon 3000 miles for some excellent pig hunting and cnc trouble shooting..lol Love joy?
Re: Wavy cuts
if u run a cut from one end to the other of the x only an one on the y only what ur cut like...ok when u jog the axes check an see if its bindingradicalrescue wrote:noclinkers does it make waves when u cut a long the x an the y . or just one an .i had a problem on my router table were it bolted to the gantry
Re: Wavy cuts
well if were doing the helicopter an ar.s an hogs u might have some helpnoclinkers wrote:Ah c'mon 3000 miles for some excellent pig hunting and cnc trouble shooting..lol Love joy?
Re: Wavy cuts
Well , if I had the helicopter, I would fly somebody in to look at my table...lol
Re: Wavy cuts
ok look at the love joy wile u jog that axesnoclinkers wrote:Well , if I had the helicopter, I would fly somebody in to look at my table...lol
Re: Wavy cuts
it is what hooks up the stepper motor to the drive sprockets
Re: Wavy cuts
Ok, thanks! Will do this tomorrow.
Thanks for all the advice everyone!!
Re: Wavy cuts
so what have u came up with..? did u try any other drawing
Re: Wavy cuts
I did with no change.
Tm says I need to stiffen up the table.
I don't understand why torchmate has the customer add support parts to the table to make it functional, they should just sell them that way, but I am adding braces to the table to try and solve my problem.
Tm won't do any more trouble shooting until I eliminate the table wobble.
Re: Wavy cuts
what speed are u cutting at..what amps
Re: Wavy cuts
I'm running the manual specs for fine Cut 14 gauge. My amps are @45 V @74 speed @150 cuts better @220, but lots more wobble.
