3d "soccer ball"...definitely NOT a fire pit
I watched the "geodesic fire pit" files get a lot of attention and get taken down, so I thought I'd post this file I worked on over the weekend. You can get half of the dome in a 4' x 4' sheet. The bend angles are 138 degrees for the hex to hex parts, and 142.5 degrees for the hex to pent parts. if you start bending at the score lines, essentially the faces will start to match up. As for artwork, you can add anything you like. I marked to top facing edge with a point, so you could know how the pieces will face after being bent. However, the dxf if for a bottom, so it would be the opposite edge for the top. at scale, it should make about a 27" diameter sphere.
- East German
Re: 3d "soccer ball"...definitely NOT a fire pit
Regards Peter
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
it looks amazing. What thickness to you cut it out by. Also I'm Aussie, so if I scale this in AutoCAD x 25.4 it should work out the same?
The bend allowances are for 11ga or 3mm...yes, scaling it by 25.4 will convert it to metric.
thank you for the help.
Thanks for the share kaos
dont put logos on their he got a copy right for doing that on a geodesic shape
I'm thinking about getting a copyright to hang photographs on the wall, perhaps in a predetermined size, rectangular shaped aparatus.
- Capstone
thanks for the share
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Thank you for the file share
Omax 80X Waterjet 6 x 12 with Tilt-A-Jet
CamFive 150w Co2 Laser
Miller Mig & Tig
Whitney-Jenson 20 ton Punch Press
Atlas Lathe
Miller Mig & Tig
Atlas Lathe
- steel 35
I think I may try the lighted version! Thanks.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- Poh
Thank you for sharing!
Poh, Stainless is Forever!!!
Torchmate 5'x10' water table,Torchmate 8 CAD
Hypertherm HSD 130
Plate Marker ,Tube Cutter, and Oxy-Acetylene
Miller Dynasty 350
Miller 350 p
Hypertherm HSD 130
Miller Dynasty 350
Miller 350 p
Nice!! Thanks for the share!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- someguy
Thanks for the share.
- d2day
Thanks for the share, I appreciate your efforts and skill..great file
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
SheetCam
ArtCam 7.0
CNC Router
ULS Laser
Cut Shop Software
LCTHC
Thank You for the NOT fire pit.
- Peechy
Better wear steel toe boots kickin that sucker around
Thanks for the soccer ball!
Thanks! if anyone has any other "non fire pit" balls, I wouldn't mind the file... just sayin.
Very cool. How do you guys calculate your bending angles?
Wondering if it's easier for me to make each piece individually due to the size of my table
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
- Scratch
That's pretty cool! Thanks for sharing. I might make one solid just for funsies.
I must have missed the thread with the fire pit thing... I assume there was lots of drama... Is the thread gone? I like to see that stuff it makes me laugh.
lol lots of drama. That's an understatement
It's good for a laugh for sure
Search geodesic fire pit. It will come up
- Gamelord
- 4.5 Star Member
The angles are listed in the original post. To get the angles right, you can cut out a triangle with one angle at the correct degree and then tack it or clamp it to the pieces to be welded together. Once you get two together, the rest should start falling into place.
Torchmate CAD
Torchmate CAD
