I've been having trouble with my Mach3. It does not like to load in the preset voltage setting.
It seems to be locked on the CandCNC hub setting. I'm still quite new at this but I thought the S379 code should override the hub and set Mach to 79V.
Another odd anomaly I am having is sometimes the S10 does not turn off the DTHC at the start? As you can see in the screenshot taken after I ran the first section of the program posted below. Maybe the problems are related?
N0010 (Filename: 8in line.tap)
N0020 (Post processor: DTHC-HYT-TAP_SoftPierce+Marker-rev11J.scpost)
N0030 (Date: 13/03/2016)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: 8in line)
N0080 (Operation: No Offset, Unnamed Level 1, T5: Fine Cut-Mild-Steel-16ga)
N0090 (DTHC has been disabled in this tool)
N0100(Preset Volts: 79) (Preset AMPS: 40)
N0110 ( Air Pressure Preset: 75)
N0120 ( Soft Pierce : 60 percent )
N0130 (This code for use with Ether-Cut upgrade 12-19-14 or later)
N0140( Suggested Tip Size: 45 ) ( DTHC Delay: 3 sec )
N0150 ( Min Cut Length for DTHC ON : 1 units )
N0160 S900
N0170 S10 (DTHC ON/OFF is run by rules)
N0180 S379 (Preset Volts set to 79 Volts)
N0190 S440
N0200 S875 (Set Air Pressure to 75 PSI)
N0210 S530 (DTHC Delay set to 3 Seconds)
N0220 S711 (DTHCIV tuning set to level 1)
N0230 S701 (Clear S Register)
N0240 M00
N0250(Paused: Check the DTHC Settings Hit RUN to continue)
Hub setting. Note I did change the voltage to 150V from the previous 153V before this screenshot.
Preset Voltage not loading into Mach3
DIY CNC 4'X4' Plasma table with water table.
Hypertherm Powemax 1000 with modified hand torch
CANDCNC BladeRunner Dragon Cut 620-4 EtherCut, DTHCIV and Feather Touch Ohmic Sensor
Mach3, Sheetcam
Mach3, Sheetcam
Re: Preset Voltage not loading into Mach3
You may get a faster reply by going to their form off the CandCNC site.
Thanks guess I should. Thought I would have a faster reply here though
Mach3, Sheetcam
Mach3, Sheetcam
