Hypertherm cpc port terminal?
tm america
Post by tm america »
I need some help identifying the type and maybe even the part number for the male terminals that the hyperthem cpc connector uses..The cutters come with the one of the connectors attached to the remote torch trigger pendant..I am getting tired of buying the Whole connector just to get the terminals..If i could figure out which type of connector it is or the part number so i could order them from digikey it would be very helpful?Thanks in advance i am sure there are lots of other guys thinking the same thing..I did a search and didn't find anything on here
davek0974
Re: Hypertherm cpc port terminal?
Post by davek0974 »
where are you?
i have plenty of spares from my 'adjustment' ;)
tm america
Ok i think i answered my own question looks like these are the correct connectors,terminals and tools ..These are the digikey part numbers.....
conn plug=A1358-ND
conn backshell =A32516-ND
conn pin 14-18awg tin crimp= A31998CT-ND
contact extraction tool=A1329-ND
tm america
davek0974 wrote:where are you?
I am located in Griffith,IN About 30 minutes south east of Chicago
davek0974
Post by davek0974 »
Ah, bit of a distance from UK then :)
glad you found the codes
Newark Electronics has them too I just soldered them on no need to buy a crimping tool
the pin is 25c8076 $.55 each
http://www.newark.com/te-connectivity-a ... Categories
plug 4.08
