What's the trick for using M11 M10
Greolt
Post by Greolt »
Mach3 LPT
When using M11P1 to start the torch it does not start until an axis moves.
If I require a dwell after M11 to allow pierce time, and then move to cut height, the torch will not turn on until the cut height move commences.
This nullifies the dwell. What is the trick?
M624 ' this is my touch off macro which leaves the torch at pierce height
M11 P1 ' start torch
G4 P200 ' pause for 200 ms
G0 Z1.2 ' move to cut height
G1 X100 Y100 F4000 ' begin cut path
WyoGreen
Re: What's the trick for using M11 M10
Post by WyoGreen »
There are many threads on here for using the M11 M10. It would probably be easier to just take a look at them and see if it helps.
http://www.plasmaspider.com/search.php?keywords=M11+M10
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Assuming your pierce height is always the same then give Mach what it wants, e.g. assuming your pierce height was 4mm, and if M10/11 works with any axis movement, insert a very short move after M11 P1:
G0 Z0.01 '1/100th mm move to allow torch to start
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
vmax549
Post by vmax549 »
YOu can use a phantom axis call on the same line as well and that avoids the extra short move line
M11 P1 C0
G04 P200
Greolt
Post by Greolt »
beefy wrote:Assuming your pierce height is always the same then give Mach what it wants, e.g. assuming your pierce height was 4mm, and if M10/11 works with any axis movement, insert a very short move after M11 P1:
That will be a problem Beefy.
Say pierce height is 3mm. Torch fires and moves down to 0.01mm height. Then moves back up to 1.5mm cut height.
Better would be to have, M11P1 - G0 Z pierce height + 0.01
However pierce height is a variable read in by the M624 macro. So I don't know how to do that.
Greolt
Post by Greolt »
vmax549 wrote:YOu can use a phantom axis call on the same line as well and that avoids the extra short move line
M11 P1 C0
G04 P200
I already played around with that concept Terry. Probably not for long enough but I found it a little iffy.
If C axis is not enabled the move command is ignored. No problem, it can be enabled and still be a phantom.
But if C is already at zero then it is also ignored.
Maybe something like this would work.
G0 C1
M11 P1 C0
and
G0 C0
M10 P1 C1
vmax549
Post by vmax549 »
You don't want the move to have any length as it just adds as time as a dwell. I will look back at how teh laser guys delt with it.
vmax549
Post by vmax549 »
Teh M11 P1 C0 will work just fine without any actual c motion. The C does have to be active though.
With C dro at 0.000
M11 P1 C0 turns on output 1
M10 P1 C0 turns off output 1
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Sorry Greolt,
I meant to say "G0 Z3.99" As you can see after the code I wrote, "1/100th mm move to allow torch to start" (4 - 0.01 = 3.99).
LinuxCNC
Coreldraw 2019
Greolt
Post by Greolt »
vmax549 wrote:Teh M11 P1 C0 will work just fine without any actual c motion. The C does have to be active though.
With C dro at 0.000
I don't know what I am doing different but that is not what happens here.
If C is already at zero and I command M11PI C0 the output DOES NOT turn on
If C is already at zero and I command M11P1 C1 the output DOES turn on.
vmax549
Post by vmax549 »
I just tested again It works fine here and always has. I am running LPT what controller are you running ?
(;-) TP
vmax549
Post by vmax549 »
One more round of tests show it works from Gcode, Mdi and scripting.
Greolt
Post by Greolt »
Terry
Redid my tests. Gcode and MDI. Definitely does not work as you describe for me.
No idea why. Mach3 R3.043.062 LPT
Anyway it does not matter. My method of calling C1 first, then M11P1C0 does work. So it is not a big deal.
Have the C axis set at one step per unit, so delay should be virtually non existent.
Thanks for checking it out.
Doing my first cuts on my table. All going pretty good so far.
Just got to sort out my missing ArcOK signal. Then everything will be sweet.
Then when I get really rolling,I will swap over to UCCNC and give that a go.
Greolt
Return to “Mach3 & Mach4 CNC”
