Hi.
I had some dxf files on my flash drive, which I lost. I have the tap files on my computer and was wondering if there is any way to convert the tap files back to dxf files. Any help would be greatly appreciated.
Thanks, Pat
.tap to .dxf conversion
Re: .tap to .dxf conversion
tap is g-code and only remotely related to the original drawing. I don't know of anyway to go back the other direction. Only thing you might could do is do a simultion on the screen and screen grab of the toolpaths and use the auto trace in something like Inkscapre to get back to vectors. Won't be the right size but that is easy to change once its back in vector
Pat
There are probably a number of options, however the one that I have is called NCplot. Does a pretty good job of converting nc files to DXF.
Used to be a free version but does not look like it is still available. It is a bit pricey. When I bought it, it was much cheaper.
However the free trial period is 15 days. Plenty of time to convert all your tap files.
Take a look at it. It is a very comprehensive program.
- WyoGreen
I found this link some time ago. This method did not work for me, but it may for you.
http://forum.sheetcam.com/viewtopic.php ... 13230bcf0d
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
You can easly do it in SheetCam. Import teh Tap file into Scam then you can even reverse teh offsetting if you know what it was . Then post it out as a DXF file. You will get a very close to perfect replica.
(;-) TP
(;-) TP
Thanks to all for the advise. I have never used any of the programs mentioned. Is SheetCam expensive? It sounds like it's just what I need. Or maybe I could try the free NC plot program, hopefully it wont take me the full 15 days to figure out how to use it. Thanks again,
Pat
Pat
Pat
Pat
