World's first Solar Powered Motion Activated Donation Box
- Craig
Made this for the Battleship Iowa.
Craig Johnson
Craig Johnson
Craig Johnson
Re: World's first Solar Powered Motion Activated Donation Box
Nice work. So, motion activated, I assume the lights come on when someone is walking by to draw attention? Does it play a recording as well, maybe some audio talking about the ship etc???
Shane
Shane
Beautiful work, that is amazing .Thanks for sharing.
Jim
Jim
- East German
Wow!!
Great work!
Regards Peter
Great work!
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- Capstone
That is next level... Thanks for sharing Craig
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Amazing!
It is awesome to see the talent and abilities that you all have, which inspire me as a newby to keep trying something different!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
That looks amazing and for a worthy cause.
LDR Motionsystems 4x4 plasma
Hypertherm 45
Laser 4 X 4
Full woodshop
Hypertherm 45
Laser 4 X 4
Full woodshop
- little blue choo
AWESOME!!!
Rick
Arclight 9600 4x8 table
- Craig
Thanks All, this one is powder coated and plated.
The way I figured it you can't get someone to put money into a donation box unless you can get them to the box, everyone like bling.
It did get me thinking and my next donation box will be more like a game. It will be similar to those Pachinko games but with coins instead of balls.
The coins drop in from the top and the player can turn knobs to catch and redirect the coin into one of 4 slots in the bottom an optical switch will see the coin fall and play a sound from say the 16 inch guns going off another slot might have 40mm gun sounds. It will also light up red LED's from behind that are synced with the sound, I think kids will love this game.
I plan to use a motion sensor so when a guest approaches the game it will play this sound.
https://www.youtube.com/watch?v=B0B8iIYjO4U
I started this prototype board to help me learn the physics of the coin fall. I still have a lot to figure out but will report back when I get farther along.
Craig Johnson
Thanks Shane, it's funny you mention that, I also had the idea of sound effects but it ran down the battery too quickly.Shane Warnick wrote:Nice work. So, motion activated, I assume the lights come on when someone is walking by to draw attention? Does it play a recording as well, maybe some audio talking about the ship etc???
Shane
Craig Johnson
- Attachments
- Prototype board
- DB Proto-1.jpg (846.93 KiB) Viewed 3413 times
Craig Johnson
- Sampson Jones
excellent as usual Craig !
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
I concur! Great job!
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
- Craig
Here is the DXF file for the Iowa badge. Craig Johnson
- Attachments
- Donation Box 2.zip
- (769.94 KiB) Downloaded 102 times
Craig Johnson
Do you have any pics from the build process? It would be great to see them.
How did you do the smooth bends?
- tnbndr
Nice work.!!!
Can you post what you used for the battery operated motion detector and lights?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- Craig
Sorry Mike no pics of the build I changed my design a few time so they might be confusing anyway.whiskeymike wrote:Do you have any pics from the build process? It would be great to see them.
I used 18g cold rolled steel so I could bend it by hand. It's a little thinner then I like to use because it dings a little to easy for an outside hands on piece. I started at the top and used spring clams and vice grips to hold the sides down and just tack weld and bend as I go down the sides making sure to keep the overhang on the sides even.
Tnbndr this is the IR motion detector I used it's not outdoor rated so I mounted it inside and cut a hole in the side for the sensor to stick out of I sealed it all with silicone and used a spray on silicone to keep the connections dry.tnbndr wrote:Nice work.!!!
http://www.amazon.com/gp/product/B00HJ6 ... ge_o03_s00
The LED's are waterproof strip lights with adhesive backing they where left over from another project and can't remember where i got them.
Craig Johnson
Craig Johnson
WOW!!! Craig another fantastic job, how do you come up with this stuff!!! I don't know what they are paying you but I am sure it's not enough.
- Craig
Thanks, being a volunteer I get payed by being involved with a piece of American history but also it is quite an honor for me that they think enough of my work to display it on board I also enjoy the fact that my work will be viewed by hundreds of thousands of people every year.MadMetal2000 wrote:WOW!!! Craig another fantastic job, how do you come up with this stuff!!! I don't know what they are paying you but I am sure it's not enough.
This was installed this morning before opening and by the end of the day the box had $22 in it.
Craig Johnson
Craig Johnson
- Buzzard Gut
That is so cool Craig! Nice job to !
The older I get, The better it was!
Looks cool installed Craig do you know how much money it has made so far. And thanks i really enjoy looking at the stuff you make.
- Craig
Thanks, just found out today that the Box made $306 in it's first 2 weeks. Craig JohnsonMadMetal2000 wrote:Looks cool installed Craig do you know how much money it has made so far. And thanks i really enjoy looking at the stuff you make.
Craig Johnson
