Pierce height on multiple cuts
LEDPlasma
Post by LEDPlasma »
Hello fellow plasma tablers,
New to the forum and new to the plasma table world. I have a decent grasp and have been using my table for a few weeks now.
My question is, When i have more than one pierce on my part that I am cutting out, say with half a dozen holes or similar. My torch goes to its first pierce, travels down and finds the material and comes back up to pierce height and everything is all good. BUT, then when it is finished that cut and moves over to the next "hole" or "pierce" the torch does not go down to find material height and it just starts piercing at a random height (which is always to high) and usually ends up gouging the material until the arc finds its cut height and pierces through.
I have been trying to figure it out but now i am here asking some experienced people. In result i have been left with using a big "lead in" on sheet cam just so the part is cut completely.
thanks for your help.
LED Servives
Alberta, Canada
SeanP
Re: Pierce height on multiple cuts
Post by SeanP »
Do you use sheetcam?
You need to edit the ref distance in the post processor file.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
LEDPlasma
Post by LEDPlasma »
SeanP wrote:Do you use sheetcam?
Yes I am using sheetcam.
Is 100mm what your setting is at?
I am using post processor Mach 3With THC - G31
SeanP
Post by SeanP »
Yes that's it 100mm is what mine is set to, you can go less
Powermax XP45
Table build gallery
LEDPlasma
Post by LEDPlasma »
I got it figured out today :) thanks alot for your help!!
Return to “SheetCam”
