Butterfly from puzzle
- trucks1948
This is a butterfly i made for my wife for her flower garden.Made from a puzzle i downloaded here.43in tall.jim
Re: Butterfly from puzzle
Wow, What an awsome job. Love the paint job too!
- trucks1948
Thanks,i do the cutting and my wife does the painting,works good cause i like to cut and she likes to paint
- trucks1948
Here's another butterfly from a puzzle i cut for our soon to be daughter in law.jim
could you share the dxf's? thanks
- trucks1948
This is the puzzle i used for the butterfly.just enlarge it to whatever you want.Make sure you set the slots for the thickness metal you are using.Jim
Patrick
- admin
- Site Admin
Patrick, just tried to open it Corel X3 also and had a problem. Opened fine in Corel 9. Try this cdr file, should work fine for you.
Thank you. This is a very cool file. I was showing this pic to some I know and he wants me to cut 2 of them for there inlaws. $$
Patrick
I pulled this file into sheetcam and it has almost 800 start points, I tried join command, no luck. Can anyone point me in the right direction as to why it's behaving like this?trucks1948 wrote: ↑Mon Jun 21, 2010 2:55 pm This is the puzzle i used for the butterfly.just enlarge it to whatever you want.Make sure you set the slots for the thickness metal you are using.Jim
Thank you for Your time.
dynatorch xls, hypertherm 125 generator, Oxy propylene torch, multiple lathes, mills and saws.
Here is a file from here a long time ago, that I cut from 14 Ga posted back in 2014
That one worked really well. thank you very much.acourtjester wrote: ↑Mon Apr 22, 2024 5:13 pm Here is a file from here a long time ago, that I cut from 14 Ga posted back in 2014
butterfly-jim 14ga.dxf
Thanks , just finished resizing all the slots in inkscape . I drew a .075 square and enabled snapping then moved nodes to narrow slots . It took a long time . There has to be an better way ?
I used the offset, trim and fillet functions. it took me probably an hour to do the entire drawing. Not bad, considering I frequently am tracing custom lettering from a picture because sign slapper falls on it's face when attempting to do so.
Thanks , did not think of trying to do it with offset .
Thanks for the share
