It is currently Mon Jul 23, 2018 4:07 am
need a fire ring with frogs
gene portable welding
Postby gene portable welding » Mon Jul 06, 2015 10:07 am
some of you great artis can get me a frog fire ring . i have a hard time drawing a square with a square
many thanks to the great artis
thermal dyn 152
4 x 8 eagle plasma table
400 amp portable welder
250 amp Lincoln stick
miller cp300 w/ S-52d
miller cp300 w/S54a setup for alum
13 x 60 south bend lathe
emco mill
Amer bender
http://www.facebook.com/gene'sweldingandfabrication :)
james.davis
Re: need a fire ring with frogs
Postby james.davis » Mon Jul 06, 2015 3:23 pm
Postby gene portable welding » Mon Jul 06, 2015 7:10 pm
tried to open dxf said acess denied
thermal dyn 152
emco mill
Amer bender
1MORECUT
Postby 1MORECUT » Mon Jul 06, 2015 10:01 pm
See if this one works. :D
John 8-)
Postby gene portable welding » Wed Jul 08, 2015 3:48 pm
nice frog but need it in a fire ring thanks
thermal dyn 152
emco mill
Amer bender
Postby BrianMick » Fri Jul 10, 2015 9:40 am
so What?.......You want us to draw a rectangle? And Insert a frog?......Sounds pretty easy.......unless you what something more complicated
You haven't described to us what you need.
Postby gene portable welding » Fri Jul 10, 2015 11:05 am
I can make the firering but when i go to put the frogs in it there upside down when i try to select just the frogs i get everything . i'm new to this so bear with me. a guy draw a frog for me and it's just what i wanted. any help would be invitened
thermal dyn 152
emco mill
Amer bender
beefy
Postby beefy » Fri Jul 10, 2015 6:57 pm
gene portable welding wrote:some of you great artis can get me a frog fire ring . i have a hard time drawing a square with a square
If you have a hard time drawing a square with a square, then I think your efforts would be better served by learning how to use your software. I get regularly gobsmacked by how many members just ask someone to do something simple for them instead of asking HOW to do it.
I started from the beginning and never asked once for someone to draw something for me. If I didn't know how, my next job was to find out how.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
Gamelord
Postby Gamelord » Sat Jul 11, 2015 2:39 pm
What software are you using? That would make it easier to give you help on how to change your drawing.
Torchmate CAD
Postby gene portable welding » Mon Jul 13, 2015 12:04 am
qcad and sheet cam if you get it thanks a millon
thermal dyn 152
emco mill
Amer bender
dava
Postby dava » Fri Jul 17, 2015 4:51 pm
How is this?
Frogger.dxf
cpreston
Postby cpreston » Fri Jul 17, 2015 11:49 pm
Messing around on a Friday night and came up with this
radicalrescue
Postby radicalrescue » Mon Jul 20, 2015 7:14 pm
cpreston wrote:Messing around on a Friday night and came up with this
hay i want to make sure u got the credit for the the post i pasted it on to another member thanks for sharing it
Users browsing this forum: jackleg007 and 13 guests
