Gluing metal parts together
AIRFLOWKID
Post by AIRFLOWKID »
Plasma Dudes,
I'm making a mirror frame,basic metal frame with 2 layers of 5.25" leaves on it. Now each layer is finished and sealed.Leaves are done seperately,finished and sealed then glued on with urathane glue.Problem is I'm not happy with the holding power of the glue.Either because glue was put on top of finish or glue was a bad choice?What type of glue should I use? I was also thinking of just making 3 separate layers and using a decorative screws to hold together. Please help!!
Thanks so Much,
Tim
Red Robin Creatives 8-)
mdwalker
Re: Design Problem
Post by mdwalker »
Any way you could post a picture of the part you are having a problem with? What about something like JB Weld or a simular product?
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
ericandmollie
Re: Design Problem
Post by ericandmollie »
What about an 2 part Epoxy? I have never tried to glue metal down, but I also have access to a spot welder though, which makes things really convenient!
Scratch
Re: Design Problem
Post by Scratch »
I've used JB weld with good results. I hit the contact areas with a had grinding disk before I gooped them up though. How big was the pieces you glued on...? Is weight just too heavy for the glue maybe?
AIRFLOWKID
Re: Design Problem
mdwalker
I'll post pics in the next couple of days. Thanks guys for helping me!
Tim Red Robin Creatives
AIRFLOWKID
Re: Design Problem
Plasma Dudes,
Here is the picture of the frame.Hope you can help me with this project. Thanks so much
Tim Red Robin Creatives 8-)
AIRFLOWKID
Re: Design Problem
Here are some more pictures
Tim
AIRFLOWKID
Re: Design Problem
Ericandmollie,
I tried the epoxy and it worked great.Thanks for the help!
Tim Reamer
