Corel x5 vertical text to a curve
762frmafr
Post by 762frmafr »
I don't know what i am missing on this one, but i can't seem to figure out how to do it correctly. I would like to have vertical text fitted to a curve....like a circle or whatever. Anyone? Thanks in advance.
Re: Corel x5 vertical text to a curve
Sure would like to hear an answer for this one. :D When I need letters done like that I do it the hard way, draw circle, type letters vertical near the circle, calculate angle to where each letter will be, rotate each letter to angle and move them into place. Lots of work so if someone has answer please post!!! :?: :?: :?:
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
While you are in text to path "mode", look at a box in the top left corner and hover your mouse over it. The words will come up "Text Orientation". Drop the selection box down and click the one for vertical text.
Hope that helps,
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
762frmafr
Post by 762frmafr »
beefy wrote:While you are in text to path "mode", look at a box in the top left corner and hover your mouse over it. The words will come up "Text Orientation". Drop the selection box down and click the one for vertical text.
Hope that helps,
Keith.
I know which one you are talking abut Beefy...and I have tried that.... it doesn't seem to be working... maybe I am doing it wrong. The word becomes all jumbled and smashed together when i try using that.
Maybe your font is to large for the curve???
DXF
Post by DXF »
762frmafr wrote:I don't know what i am missing on this one, but i can't seem to figure out how to do it correctly. I would like to have vertical text fitted to a curve....like a circle or whatever. Anyone? Thanks in advance.
Don't know for sure, never tried it. Click: Help - Help topics - fitting text to paths
Dave Hanks
plain ol Bill
Post by plain ol Bill »
What is the size of the circle and size of the font?
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
762frmafr
Post by 762frmafr »
plain ol Bill wrote:What is the size of the circle and size of the font?
Roughly... 18 inch circle and 1 inch wide by 5 inch tall letters.
muzza
Post by muzza »
As Keith explained it above, here is a youtube clip showing how to do it, pretty crappy audio but shows what to do.
Murray
https://www.youtube.com/watch?v=gQIpCYtoOZM
762frmafr
Post by 762frmafr »
muzza wrote:As Keith explained it above, here is a youtube clip showing how to do it, pretty crappy audio but shows what to do.
Murray
As I stated before, this does not work. The letters become jumbled and smashed together.
muzza
Post by muzza »
Works for me every time, have you dragged the word out as shown in the video to give enough space between letters and is your path long enough to fit the text on it?
Murray
762frmafr
Post by 762frmafr »
The difference between the video and what I am trying to do is he is doing it on a straight vertical line. Which works every time for me as well. What I am trying to do is fit vertical text to path on a CURVE.
srp
Post by srp »
Is this what you are attempting?
LETTERS ON CIRCLE.cmx
(12.81 KiB) Downloaded 93 times
muzza
Post by muzza »
This is using the method on the video, are you trying to add the text to the left line (left side of screen shot) or to the right (right side of screen shot)?
there's a difference
Murray
762frmafr
Post by 762frmafr »
srp wrote:Is this what you are attempting?
I do not have Corel at home. I will have to look in the AM.
762frmafr
Post by 762frmafr »
muzza wrote:This is using the method on the video, are you trying to add the text to the left line (left side of screen shot) or to the right (right side of screen shot)?
Murray
To the right side of the "curve".
muzza
Post by muzza »
OK just in case there's something not catching on with the video this is what I did
Draw the path for the text.
Type the text and size it. (in this case "TEXT TEST")
Select the shape tool and use the right arrow to drag more gap between letters
Select "Text", then "Text to Path"
Place it on the path where you want it
Then go to "Text Orientation" (top left) and select the bottom one for vertical orientation
Done
If you were doing it on the left side it would automatically want to place the text running from bottom to top as we read and write in the western world way of left to right so to make it run top to bottom you have to play with the mirror function.
Murray
762frmafr
Post by 762frmafr »
muzza wrote:OK just in case there's something not catching on with the video this is what I did
Done
Murray
That is exactly what I am doing only on the inside of a circle.
muzza
Post by muzza »
Like this
I used the same method except that I placed the text centred over the line before hitting orientation. Then I went to "Arrange" "Break Text Apart" and then manually adjust position of text.
Murray
762frmafr
Post by 762frmafr »
muzza wrote:Like this
Murray
I will try that in the AM. Thank you.
WyoGreen
Post by WyoGreen »
Looking in the user manual for X7, there are two types of text, artistic and paragraph. Paragraph text can only be fitted to open paths. Artistic text can be fitted to open and closed paths. Maybe you're using Paragraph text?
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
muzza
Post by muzza »
Paragraph text is where you draw the shape that you want to contain the text and then the text will fill that area as typed and adjust the text size to suit the shape as you go.
Just for future reference for anyone that may look back at this thread I'll explain a little clearer for placing the text to the left line as shown in this screen shot so it reads top to bottom.
You basically do the same as above except that before you fit the text to path you mirror the text sideways so that it is reversed and reading backwards.
You then fit text to path and then select the same text orientation to make the letters vertical but each letter is backwards so you now have to mirror the text sideways again to put them back around the right way. If you don't do this the text will read from bottom to top.
Murray
762frmafr
Post by 762frmafr »
I think i figured it out. I ended up having to type one of them backwards so that it would end up top to bottom. But I got it.
