Tool & Garage Organization Thread
Capstone
Re: Tool & Garage Organization Thread
Post by Capstone »
Here's a Mill Collett holder that's specifically designed to mount on the side of a CNC Vertical Mill (Haas VF series) You will need a bend/break. This will work well with 16ga/14ga HRS. The design looks slightly different from the picture. There's only one set of tabs to attach to the machine and the logo on top has been replaced with a length of metal that should be bent down to add strength, but you certainly could replace it with a logo of your choice along with the side CMD logos.
Collet Holder v3_blank.svg
There's a shelf that's tack welded on to the bottom as well.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
triumph001
1/2 Star Elite Contributing Member
Grinder Rack
Post by triumph001 »
This bends easily and is then welded up. Bottom is expanded metal welded in place, keeps it from being a dust collector. Works well for our dewalt 4.5" angle grinders.
Grinder Rack 2.0.dxf
otisa2007
Re: Grinder Rack
Post by otisa2007 »
i like it very nice thanks for the share
Proballz03
Re: Grinder Rack
Post by Proballz03 »
Thanks for sharing.
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
Capstone
Re: Grinder Rack
Post by Capstone »
Nice set up thanks for the share. Gave me some new ideas
Phil
CNC Metal Design
JD Squared 4x8
alonzo83
Re: Tool & Garage Organization Needed
Post by alonzo83 »
kkroger wrote:Air Tool Racks as I do them, also has a spot for the never present Air Tool Oil.
I powdercoat them in a single stage "Chrome" which is really just a silver not a two stage Chrome look.
I also do some in Black Wrinkle... The two end holes are 16" on center to fit stud C2C width.
I bend them in the sheet metal brake so there are no slots...
I also have a Visegrip rack that hangs them from the adjusting screw instead of the jaws.
ETA I make them from 18 ga sheet, works fine but I don't have the weakening brakeless bend slots.
What font style and software do you use for your letters?
I am new to this and my cad software only has one font style.
alonzo
dynatorch xls, hypertherm 125 generator, Oxy propylene torch, multiple lathes, mills and saws.
someguy
Re: Grinder Rack
Post by someguy »
Nice design, thanks for sharing.
yeomansjon
Re: Grinder Rack
Post by yeomansjon »
Nice job! I can't make one of these fast enough... Might ad it to the shop tonight.
This link should be in the Garage Tools Post...
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
www.facebook.com/fastjonnycustomdesign
admin
Site Admin
Re: Grinder Rack
Post by admin »
yeomansjon wrote: This link should be in the Garage Tools Post...
Good call...I have merged this with the garage tools thread. Great grinder rack! Love this thread.
kkroger
Post by kkroger »
alonzo
That font is a windows native font TTF (True Type Font) called Stencil or Stencil Std, both should be on your machine already.
You can do it a few different ways, if you have Inkscape (free) you can just create the text in something like Paint, then path trace it. Or just do it in Inkscape Directly, Or there is a program called Stencil Fonts 1.0, and a program called Desk Engrave with Desk Engrave you get the DXF path but you will have to tab your letters so they don't have dropouts yourself, even with Stencil Fonts you will probably have to make adjustments. with both Inkscape and CAD you will still have to tab them in yourself.
kkroger
Post by kkroger »
I have Stencil Fonts... you will STILL have to mess with the font to get the splines just right...
there is a website with fonts... http://www.1001fonts.com/search.html?se ... +&x=13&y=0
Hot Metal
Post by Hot Metal »
Thank you all for the great ideas!
shinertx
Post by shinertx »
Thanks for the grinder file it will come in handy next to my grinding bench. Robert
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Pfefferneusse
Post by Pfefferneusse »
Here are a couple that I haven't seen in the thread yet. There is a rack meant for the top of a welding tank that I've seen around before, but not in the thread. EDIT: If it wasn't obvious, the dashed blue lines are indications of where to bend.
Tape Measure Holder
Holds around (10) 25-footer tape measures
Tape Measure Rack.dxf
Welding Tank Hooks
Great idea, but I can't claim credit for it. Hank your mask, wrench, etc.
Welding Tank Hooks.dxf
Dust Pan
Dust pans are cheap enough to buy, but where's the fun in that.
Dustpan.dxf
Happy cutting
agteacher
Post by agteacher »
Pfefferneusse wrote:Here are a couple that I haven't seen in the thread yet. There is a rack meant for the top of a welding tank that I've seen around before, but not in the thread. EDIT: If it wasn't obvious, the dashed blue lines are indications of where to bend.
Tape Measure Holder
Welding Tank Hooks
Dust Pan
Dustpan.dxf
Happy cutting
Do you have a picture of the tape measure rack by chance?
Randy Dobbins
Welding Teacher Humble ISD
Pfefferneusse
Here it is in "action."
KIDTech
Post by KIDTech »
Ah the tape measure, seems to be the most common tool with legs....
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
Pfefferneusse
You need a rack to hold 10 because even with just 5 people in the shop, there will be none around when you need one.
agteacher
Post by agteacher »
KIDTech wrote:Ah the tape measure, seems to be the most common tool with legs....
You don't even know!! In the school setting I think they "run" off sometimes! Worse part is I am sure the ones taking them don't even know how to read one!!
Randy Dobbins
david47julie
Post by david47julie »
These are all great ideas thanks for sharing
SjHeeney
Post by SjHeeney »
thanks for sharing
Zeke
Post by Zeke »
JayG
Post by JayG »
Thanks for ALL the organization ideas. Now to put 'em into use!
PlasmaCam DHC2
Hypertherm Powermax 85
Miller EconoTig
Miller MIG
Lincoln MIG
Millwright Knee mill (older than me!)
LeBond Lathe (older than me!)
Pfefferneusse
Figured I'd chuck these bottle tags in here, too. Anyone who's seen "a full bottle with "MT" written on it in paint marker might get some use out of these.
Bottle Markers.dxf
dustyscustomwelding
Post by dustyscustomwelding »
Here are some of the projects that i adapted from here. Thanks for all the ideas!
Dusty
Owner
Dusty's Custom Welding and Fabrication
https://www.facebook.com/Dustyscustomwelding/
