I am looking for a file that I can use to cut large flowers ie.. sun flower, daisy, or just an artistic representation of some flower. Thanks everyone
Josh
looking for large yard art flowers
Re: looking for large yard art flowers
Hi,
I cut this sunflower for my niece a few years back. I hammered the middle part so that it was bowed out and then welded it inside the petals part. I cut a bunch of the single petals, then welded them in between the othes petals, and bent them up a little I used a piece of rebar for The stem, and a couple pieces of smaller diameter rebar To attach Two leafs to The stem. I'm not sure how large I made it I hope this helps.
Pat
I found another file with all the pieces, probably th size it was cut at.
Pat
Pat
Pat
Thank you Pat I'll try them this week
Thanks for sharing.
- Zippo
Thanks for posting.
Looks good!! Thanks
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Here is what I cut. Thank you again for sharing. My scrap yard had a pile of pickets someone scrapped so I'm using them for stems.
sorry they are turned 90deg they are off my phone
- WyoGreen
Thanks for the files. It should look good in the flower garden.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
