Opening dxf files in Coreldraw x3
Hi. I'm having intermitant problems opening dxf files from this site. I can always open them in Sheetcam.But some of them won't open in CD x3,the latest one being A Valentines Share.Any suggestions?
- Team Tracker
Re: Opening dxf files in Coreldraw x3
What happens when you open the file? Do you get an error, do you just not see anything?
1-800-590-7804
X3 came out in 2006, and at the top of that DXF file you will see
9
$ACADVER
1
AC1021
AC1021 means AutoCAD 2007/2008/2009
X3 probably doesn't recognize autocad versions after 2006
so, if you open the file in a text editor and change change AC1021 to AC1015
there is a good chance it will work, AC1015 is autocad 2000/ 2001/2002
there is usually no reason to save DXF files in those later versions, it's best to just save version 2000 (or earlier if splines are not desired)
9
$ACADVER
1
AC1021
Reid T wrote:What happens when you open the file? Do you get an error, do you just not see anything?
All it says is there was a problem reading the file.
You lost me a little.How would you open the file in a text editor? Thanks.SignTorch Vector Art wrote:X3 came out in 2006, and at the top of that DXF file you will see
9
$ACADVER
1
AC1021
notepad is a text editor, open the file in notepad
Ok.Thanks.Dumb me.SignTorch Vector Art wrote:notepad is a text editor, open the file in notepad
Thanks again it worked.SignTorch Vector Art wrote:notepad is a text editor, open the file in notepad
