I have some musical instruments cut out of 12ga metal, that are about 3/4 life size. They are all coated/painted already.
I was reluctant to weld anything on to them, as I wanted to leave it open to the customer on how to mount them (vertical, horizontal, diagonal, etc...) But now I'm left with no easy way to hang them.
I'm looking for some kind a stick-on hanger loop for them, but coming up empty. Has anyone found a good source for something like that?
Stick on wall hangers for 1' metal pieces
- steelfx
Re: Stick on wall hangers for 1' metal pieces
Colored paneling nails work great. Can't even see 'em & the piece fits flush to the wall instead of leaning out from the top.
bw
bw
Would 3M Command Strips work? I've used them on lighter pieces with great success....not sure if the 12gauge is going to be too heavy though.
Thanks, I think that is exactly what I'm looking for. Over an hour of googling didn't turn it up for me.
http://www.walmart.com/ip/Command-Sawto ... e/25634490
I'll let you know how it works-
If it doesn't hold re-glue it with silicone let it dry before hanging.
this will hold.
this will hold.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
