how does it effect cutting quality? rougher cut in some areas?
running 2 Motor guard filters one before air dryer and one after then the filter on the back of the HT1250.
Cutting all aluminum,, most cuts are fairly smooth as aluminum goes then I can here what seems like a pitch change in the torch and the cut gets rougher.
Have air gauge in back of HT never below 90. going to do a full ck on the mechanics shortly it is time to ck and tighten everything anyways..
Just wondering about the oil vapor and if it can get past 2 motor Guards..
Thanks gang
oil vapor
oil vapor
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Re: oil vapor
Once the paper element cartridge saturates the moisture and oil pass right on thru.
(;-) TP
(;-) TP
Re: oil vapor
Thank you Terry, I checked them today and seemed okay but going to pick up a couple of oil seperators. One for the outlet at the compressor and one before the dryer till the plumbing is cleaned out.. Will replace the paper filters also with new..
1250 hypertherm
CandCnC electronics
CandCnC electronics
