adbuch, I'm glad you found this! I was just about to post that exact screen shot for you, However after chatting with our technical support team there is no data on the cartridge without the SYNC system. So this reader will not work with the adapter.adbuch wrote: ↑Wed Feb 09, 2022 7:40 pm I guess Hypertherm has already thought of this, and I wasn't paying close enough attention when I posted yesterday. So it does look like you can read the cartridge without having to own one of the SmartSYNC cutters.
https://www.hypertherm.com/en-US/hypert ... ge-reader/
The new SmartSYNC plasma cutting system
Re: The new SmartSYNC system
Randy,
Marketing Data Specialist – Americas Region
Hypertherm Inc.
Hypertherm Inc.
You may have talked to business around the world, but I'm sure you will lose business of the small shops and hobbyist. Your producing a quality machine with the PMX series has forced other manufactures to improve their machines. With your policy and equipment changes you will cause many who would have bought from Hypertherm to look to another vendor. I have bought 3 in the last 6 years (the first 2 went with DIY tables I built and sold) the one I have now may be the last. New technology is great but not always wanted or needed, I still use Win 7 the newer Win 10 PC I have is not turned on much.We are not selling the previous PMX65, 85, 105 units any longer. Only SYNC systems are currently available for order as well as our PMX45 XP.
So if you are not abandoning the Duramax torches, why abandon the power supply that uses them? Or is it possible to adapt one to a Sync unit? It appears that the socket is the same from images I've seen. I'm sure some modifications might have to be made to the pins, though I haven't been able to locate a service manual for the sync to compare circuitry.
We would surely hate to see you go elsewhere when the time comes but of course every small business has to choose what is best for them and if you find that you can produce the same quality of work with other machines then of course that is something you will have to look at. Obviously, we hope that time never comes and you come to see the value of our systems over time.acourtjester wrote: ↑Thu Feb 10, 2022 10:22 amYou may have talked to business around the world, but I'm sure you will lose business of the small shops and hobbyist. Your producing a quality machine with the PMX series has forced other manufactures to improve their machines. With your policy and equipment changes you will cause many who would have bought from Hypertherm to look to another vendor. I have bought 3 in the last 6 years (the first 2 went with DIY tables I built and sold) the one I have now may be the last. New technology is great but not always wanted or needed, I still use Win 7 the newer Win 10 PC I have is not turned on much.We are not selling the previous PMX65, 85, 105 units any longer. Only SYNC systems are currently available for order as well as our PMX45 XP.
Randy,
Hypertherm Inc.
Hypertherm Inc.
I believe the pins are a different size which would prevent the Duramax from connecting properly. I can raise this question to our technical support team for clarification if you would like me to. I'll share what I can. Producing the SYNC system required retooling of our assembly line, which would not make manufacturing both systems feasible. While on a smaller scale this would be like asking Chevy to produce their new Truck alongside the old in the same plant. Pardon the example I was struggling to come up with a good one, but I hope you get the point I was trying to make. We only have so much room for our production line.djreiswig wrote: ↑Thu Feb 10, 2022 10:23 amSo if you are not abandoning the Duramax torches, why abandon the power supply that uses them? Or is it possible to adapt one to a Sync unit? It appears that the socket is the same from images I've seen. I'm sure some modifications might have to be made to the pins, though I haven't been able to locate a service manual for the sync to compare circuitry.
Randy,
Hypertherm Inc.
Hypertherm Inc.
- SegoMan DeSigns
There you have it, the high price for the cartridges is on your poor choice of communication with some (Not All) all of your loyal customers. A true test of this new system would be offer it along with the existing D.Max system to see which one sells the best.HypHyDef wrote: ↑Thu Feb 10, 2022 9:24 am We did not send out a survey as research, we had face to face conversations with businesses across the world and asked them what pain points they were experiencing. This is what led to the development of this new system. You absolutely are not forced into the new SYNC power supplies and cartridge consumables. We are not abandoning the Duramax torches or the consumables.
With no solution to use the old consumables on a sync power supply it's not feasible to make the switch.
I have cancled my order for a sync85.
Once my stock of consumables is getting low I will revist the issue
As I will need to buy all new consumables Ill look at other brands as well as hypertherm
I can understand that, you have to do what you think is best for your business. We appreciate your business and hope when the time comes you will see the benefit to our system. As long as our systems tend to last and the length of time we will continue to make consumables and torches for your current sytem it's possible that the SYNC system will also be discontinued, you never know.34by151 wrote: ↑Thu Feb 10, 2022 2:37 pm With no solution to use the old consumables on a sync power supply it's not feasible to make the switch.
Randy,
Hypertherm Inc.
Hypertherm Inc.
I understand your feelings on this but I can't think of another manufacturer that has done that, it's just not feasible from a cost perspective as well as facilities standpoint.SegoMan DeSigns wrote: ↑Thu Feb 10, 2022 1:27 pmThere you have it, the high price for the cartridges is on your poor choice of communication with some (Not All) all of your loyal customers. A true test of this new system would be offer it along with the existing D.Max system to see which one sells the best.HypHyDef wrote: ↑Thu Feb 10, 2022 9:24 am We did not send out a survey as research, we had face to face conversations with businesses across the world and asked them what pain points they were experiencing. This is what led to the development of this new system. You absolutely are not forced into the new SYNC power supplies and cartridge consumables. We are not abandoning the Duramax torches or the consumables.
Randy,
Hypertherm Inc.
Hypertherm Inc.
Physical size of the connections are different between the new system and the G4 Duramax system. see picture below. SYNC on the left, Duramax on the right.djreiswig wrote: ↑Thu Feb 10, 2022 10:23 amSo if you are not abandoning the Duramax torches, why abandon the power supply that uses them? Or is it possible to adapt one to a Sync unit? It appears that the socket is the same from images I've seen. I'm sure some modifications might have to be made to the pins, though I haven't been able to locate a service manual for the sync to compare circuitry.
download/file.php?mode=view&id=73250
Randy,
Hypertherm Inc.
Hypertherm Inc.
Well, if the sync connectors bigger, I bet somebody could whip up an adapter bushing and 3d print it out. By the reaction in this thread, I bet there would be market.
Is there a service manual available for the sync? Curious how much of the pins serve the same function. Guessing the extras are for the rf reader.
Yeah, but where's the service manual? The operators manual doesn't have schematics.
just curious, If the smart consumables are usable on the older units, then the old consumables should be usable with the smart cutter right? CNC lathe should be able to make an adapter?
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
It is a ONE WAY adapter to allow use of the newer cartridges on the older machines. I expect that on the Sync machines, the computer in the machine depends on communication with the cartridge to operate. So I would say NO, but perhaps the Hypertherm pro will step in here to verify.
Give Hypertherm tech support a call and ask.
You posted a link to the manuals after I posted asking about the service manual, but there is no service manual at the link you provided.
I'm not going to buy a sync, so I'm not going to waste my time calling them. I was just going to compare the connectors to see what is different. Surprised they don't have a manual available yet. Must be too new.
I have no doubt there will be someone who wants to try and fit the Duramax to the SYNC, it would be a shame though to void a warranty on a brand new system.djreiswig wrote: ↑Thu Feb 10, 2022 4:48 pm Well, if the sync connectors bigger, I bet somebody could whip up an adapter bushing and 3d print it out. By the reaction in this thread, I bet there would be market.
Randy,
Hypertherm Inc.
Hypertherm Inc.
The service manuals are listed on the website. you just have to click the button that says "show all"
https://www.hypertherm.com/en-US/suppor ... max65+SYNC
Randy,
Hypertherm Inc.
Hypertherm Inc.
You are correct, This is a one way adaptor. The G4 stack of consumables won't physically connect to the G5 (SYNC) Torch.adbuch wrote: ↑Thu Feb 10, 2022 7:26 pmIt is a ONE WAY adapter to allow use of the newer cartridges on the older machines. I expect that on the Sync machines, the computer in the machine depends on communication with the cartridge to operate. So I would say NO, but perhaps the Hypertherm pro will step in here to verify.
Randy,
Hypertherm Inc.
Hypertherm Inc.
Shouldn't void the warranty if no modifications are made to the power supply.HypHyDef wrote: ↑Fri Feb 11, 2022 8:21 amI have no doubt there will be someone who wants to try and fit the Duramax to the SYNC, it would be a shame though to void a warranty on a brand new system.djreiswig wrote: ↑Thu Feb 10, 2022 4:48 pm Well, if the sync connectors bigger, I bet somebody could whip up an adapter bushing and 3d print it out. By the reaction in this thread, I bet there would be market.
Decisions make, mandate is in like many things today protests do not change them.
Agreed, if an adapter is created to work with the Sync system for use with old consumables and that part doesn't cause any failures. If something is created and you are using components that are not meant to be used with this system and they cause damage or failures then that might be looked at more closely.djreiswig wrote: ↑Fri Feb 11, 2022 10:19 amShouldn't void the warranty if no modifications are made to the power supply.HypHyDef wrote: ↑Fri Feb 11, 2022 8:21 amI have no doubt there will be someone who wants to try and fit the Duramax to the SYNC, it would be a shame though to void a warranty on a brand new system.djreiswig wrote: ↑Thu Feb 10, 2022 4:48 pm Well, if the sync connectors bigger, I bet somebody could whip up an adapter bushing and 3d print it out. By the reaction in this thread, I bet there would be market.
Randy,
Hypertherm Inc.
Hypertherm Inc.
And most likely any damage to the new machine would not be covered under warranty. In other words, warranty may become void.HypHyDef wrote: ↑Fri Feb 11, 2022 1:31 pmAgreed, if an adapter is created to work with the Sync system for use with old consumables and that part doesn't cause any failures. If something is created and you are using components that are not meant to be used with this system and they cause damage or failures then that might be looked at more closely.
Im not sure you do.HypHyDef wrote: ↑Thu Feb 10, 2022 3:05 pmI can understand that, you have to do what you think is best for your business. We appreciate your business and hope when the time comes you will see the benefit to our system. As long as our systems tend to last and the length of time we will continue to make consumables and torches for your current sytem it's possible that the SYNC system will also be discontinued, you never know.34by151 wrote: ↑Thu Feb 10, 2022 2:37 pm With no solution to use the old consumables on a sync power supply it's not feasible to make the switch.
Hypertherm could also offer to purchase back all "new in box" consumables
