I plan on either modifying this or drawing one from scratch for 3/8"tjenus wrote:Has anyone done his in 1/4 inch ?? thanks KH
4x4 welding table help
Re: 4x4 welding table help
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
hemichargersrt8
mate you have shared some awesome work and would like to thankyou
Awesome work. Thanks! I too plan on modifying this to be able to cut from 1/4".
Wow, insane! I like that the clamps are available too. Thanks a bunch.
a very great idea turned into a great product thanks
I have to say thanks for the file I love the new table it is awesome
I love my CNC plasma....but have never been successful in cutting dimensional pieces with it...only art stuff. A bit hesitant to cut something like this when the laser already done for you option is already out there....
As for the sharing of the files, that is AWESOME!
Pretty neat. I'm still building my plasma table, but this would be a fun and useful project. I thought I'd add something about drilling out those holes. That always troubles me when I see that many.
"Hole Enlarging Drill Bit 5/8" http://a.co/1wLOTJ6
McMaster has a whole set: https://www.mcmaster.com/#drill-bit-sets/=16ama62
Without a mag drill, you might have a hard time holding onto a hand drill. Even though, you're just taking a shave.
- maxipetrello
Very nice work....
Maxi Petrello
Owner/Operator
www.petrellotanques.com.ar
1.5 mts x 3.00 mts Plasma Table
Tig / Mig / Electrode / Plasma
Owner/Operator
richiemirtsching wrote:I have to say thanks for the file I love the new table it is awesome
Great Work
5x10 Flow Waterjet
What thickness material did you use, and did you have to modify the tabs/slots from the drawing for fitment?richiemirtsching wrote:I have to say thanks for the file I love the new table it is awesome
3/16 and no mods great file
- steel 35
That looks very nice, finally cut my top today.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Nice
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
steel 35 wrote:That looks very nice, finally cut my top today.
Different style? what goes in the Oval Holes?
5x10 Flow Waterjet
- steel 35
Down draft table top with a long way to go; Easy access to the holes near the center some won't be accesable & Using the drops for Quarter turn clamp bottoms.tjenus wrote: Different style? what goes in the Oval Holes?
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
Here is my test cut toleranced for 3/8". I have not cut a table yet, but the tabs, slots, and holes all fit together well on the test pieces that I did cut.
Bolt hole is .675"
Slot is 1.04" x .415"
Tab is 1" x .375"
Also made them dog bones so that the corners fit easy.
I used 65 amp consumables on my Hypertherm 85 set at 40ipm.
Bolt hole is .675"
Tab is 1" x .375"
Nice table. Thanks
This has to be the best post here! I'll be pm'ing Hemichargersrt8 for a paypal address! These are great files to share! Thank you much!
Yesterday I built a fixturing table from 15" wide 3/8 thick channel. I made some upright posts from 4x4 x .250 tubing for a motorcycle frame jig. I've also got some brackets for the kneck tube adjustment. Once I finish it all up I'll make a new post to share.
Here is the 2' X 4' table I have and the clamps I cut from the file here. I welded a hanger rail under the table for clamp storage.
For you guys using your plasma tables, are the holes cutting well enough? Or do you undersize them and use a cobalt drill bit to finish to size?
- steel 35
Mine cut where the thread fit but the shoulder won't that's close enough for me, its hard on drills and make sure (your) hole's fit before cutting something like this.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
hemichargersrt8, I don't know if I'll ever build it but that is some fantastic work
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
