Fire Pit/Cooking Goodies Sharing Thread
Re: Fire Pit/Cooking Goodies Sharing Thread
Thanks for all the files !
Hypertherm Powermax 85
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Thank you all, I am still learning basic things but hop to make a surround for our firepit in the cement slab. I have the old software version of pcm (3.11), will that open the design edge pcm files?
a While back I saw the nicest BBQ GRILL with a Texan LONG HORN in the flat grill
does anybody else know what I'm talking about?
would love to see that grill again
many thanks
many thanks
ANYBODY KNOW WHAT FONT TYPE THIS IS IN?charlan3 wrote:This is a Baylor University fire pit that I made for a customer.
awesome thanks for sharing
Here is an MSU Spartans cooking grate I made for a buddy out of 1/8" stainless. I didn't get a picture before giving it to him. Hope someone can use it or modify to suit your needs.
This is a bowl base I offer with my fire rings. I roll and butt weld a 120" strip, making a 38" ring that sets right on top of this elevated base. I don't have a "standard" leg that I use... it depends on the theme of the ring.
Great files thanks for the uploads.
- Loyd
Thanks everyone. Great files.
kevin53 wrote:I thought that I attached these before. I guess that is what happens when you get old.here are some pics of a couple of pits that I did.
how big is the ring around it
ABLE CUTTING & FABRICATION
torchmate 4800
BATON ROUGE, LA
torchmate 4800
BATON ROUGE, LA
Great Posts Thanks
Thanks you guys, even though this is like five years later, great resource!
The feet are bent out to far.
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Does anyone have a blank SVG file of the snap together fire pits? I would like to do some custom collegiate fire pits for a few customers but they want them to be the snap together style so they can take apart for easy hauling while camping. Thanks in advance!
Thanks for the files guys.
As a Buckeyes fan that is great. Any chance I can get the .dxf for the ring?Deuce wrote: ↑Wed Jan 11, 2017 7:23 pm This is a bowl base I offer with my fire rings. I roll and butt weld a 120" strip, making a 38" ring that sets right on top of this elevated base. I don't have a "standard" leg that I use... it depends on the theme of the ring.
Fire Ring bowl base plate.dxf
dblas wrote: ↑Mon Nov 11, 2019 12:49 pmAs a Buckeyes fan that is great. Any chance I can get the .dxf for the ring?Deuce wrote: ↑Wed Jan 11, 2017 7:23 pm This is a bowl base I offer with my fire rings. I roll and butt weld a 120" strip, making a 38" ring that sets right on top of this elevated base. I don't have a "standard" leg that I use... it depends on the theme of the ring.
sure, no problem. Ill try to remember when I get home. I've been at FabTech, and I don't have the file on this laptop. if you don't see it within a day, PM me
Will post a dxf of the griddle or "comal" those are nice would like to make one thanks
anyone have a picture to the discada one i mow im late to the party not much to help with but tgans
- tinspark
A lot of guys use tractor plow discs and simply plug the hole and set it over a heat source . Tractor Supply sells them new for a reasonable price. Also, when guys build a smoker, they often cut the bell off of their tank to mount a firebox to a flat surface, and use that end cap as a discada.Squatchemup wrote: ↑Fri Sep 24, 2021 12:54 am anyone have a picture to the discada one i mow im late to the party not much to help with but tgans
Here is a link of a stand someone built for their discada.
https://www.plasmaspider.com/viewtopic. ... ada#p75761
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
"discada" - another term I was not familiar with. Seems like I learn a few new things every day on the forum.
bad ass man thats really good idea, great i will use this thank you
can anyone help me draw a set up of these to cut for my pits
maybe a long set to i don't mind paying just need help thank you
I have sent you a PM.
