Expanding my setup
Re: Expanding my setup
Here are the oven build pics.
Would you mind sharing where you purchased your fan and the PN#? Thanks
I got it at graingers and its a Dayton 1TDU9 High Temperature Blower, 115 Volt, 76 CFM some people use higher cfm fans but this one is perfect.
What did you end up using inside the walls as insulation? Is that just OSB or expanding foam, kind of hard to tell from pics?
Mineral wool
I would like to make a bigger oven than I already have but I dont know if I should mess with wiring.
PlasmaRoute Blaze HD 4x4
Thermal Dynamics Cutmaster A60
- Copp3r
Great looking oven... To each his own, and certainly I am biased but I prefer my roll in / flat bottom to the idea of having the oven on wheels. There are pro's and con's to each. I don't see the need to move the oven... ... and I have a rack that I hang my projects from, apply the powder coat and then wheel the rack right in to the oven. When the baking portion is over and done with, I merely roll out the rack.
Thanks for the images on the application booth. You must have been reading my mind. I've got a new shop underway and one of the items I want to built is a place to apply the powder coats. Without a booth the powder goes everywhere.
Thx
Copp3r / roger
Thx
Copp3r / roger
Thanks, a rack system would be nice.
- SeanP
Nice Job!
Can I just ask what the total wattage of the elements are?
Do you find them about right for that size of oven?
Sean
Sean
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
12000 total watts it works great great recovery time when opening the door.
- SeanP
Good stuff, thanks
Powermax XP45
Table build gallery
Table build gallery
Do you mind sharing your cost on your oven build? There is an used oven nearby for sale that is the same deminsions as yours. It is several years old and has been setting outside in the weather for a year or so. The current owner has never fired it up but says he will guaranty that it works for $1500 and will sell at $1000 without the guaranty.
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
I have around 16-1800 in it.
- CNCCAJUN
Have you calculated a cost per hour for your oven yet . . .?wickedinhere wrote:Thanks, it hits 400 in 17 minutes I will post pics of my booth when i start.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
I have not but it doesn't it doesn't cost that much to run. I don't run it all day but when i do run it its for a few hours at a time. I try to get 5 or 6 pieces lined up to powder coat at one time so i am not just doing one item at a time.
