I screwed up big time!!!!!
- Rockenjvdesign
Re: I screwed up big time!!!!!
Does anyone have this file I emailed plasma design and I guss he died and his wife doesn't know how to email the files or anything
Rocken JV Design We do it all
Plasma cam DHC2
hypertherm powermax 45
Custom furniture
Home décor
Plasma cam DHC2
Custom furniture
Home décor
- tnbndr
I attached the file a couple of posts back. It is in a ZIP file so you have to download it and then UNZIP IT to get the dxf file.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
My computer does not like this file, nothing wrong with the file i'm sure. I have had this problem on occasion with my Qcad Pro. The program stops and the only way to get the computer to close the program is unplug it.
I was hoping to cut this from vinyl first. When someone has the file open could you export it as an svg and put it back up here? I would appreciate it.
I hate when people die, I seem to be getting to the age when it happens a lot more frequently.
home built 4x4 watertable. Qcad, SheetCam and Linuxcnc
Miller 375 Cutmate
Lincoln buzz box and a Miller Mig
KNK MAXX vinyl cutter
The adventure started with a Cricut cutter that I hacked.
Miller 375 Cutmate
nobody gets out alive
- Buzzard Gut
Heres what I got hope it works! miss your posts John!
- Attachments
- Deer Scene Johns.dxf
- Johns File
- (953.97 KiB) Downloaded 201 times
The older I get, The better it was!
Thank you for the attempt @buzzard gut. When I open this file I get a few clouds of spots! Your file is 953 kb, when I unzip the package the file is 3.2 megs possibly the big size is why I cannot get it to work. Too bad, it is such a beautiful design.
Miller 375 Cutmate
Miller 375 Cutmate
I would love to have this file if someone has it.
- Joe Jones
Look at it this way ....acourtjester wrote:nobody gets out alive
"Nobody is condemned to remain here indefinitely."
Here's Wifey's latest revision.
Allen
Allen
- Attachments
- deer scene.dxf
- (801.66 KiB) Downloaded 177 times
how do you guys cut that without it warping? or are you just pinning it against the wall to "unwarp" it?
If it's warping, are you cutting too slow? I have a downdraft table and I think the air moving past the steel probably helps in keeping the temp. down. Just my thoughts.
Allen
Allen
Is there a DXF file of this? It looks amazing!!
Thanks JB Designs
Thanks JB Designs
- Larry83301
The post three up from yours has the file in it!JB Designs wrote:Is there a DXF file of this? It looks amazing!!
Thanks JB Designs
