Smudge Pot files anyone?
tinspark
Re: Smudge Pot files anyone?
Post by tinspark »
you can open the DXF file above and check the sheet size.
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
kbenz wrote: Fri Dec 10, 2021 1:01 pm How much material does it take?
I have attached a screen shot with dimensions so you can get an idea of the overall size. Dimensions are in inches.
StumpFAB
Post by StumpFAB »
I’ve got it nested to fit two of them on a full sheet of 5x10 with virtually no waste.
Here is one set fit to either a single 4x8 sheet or cut from two 4x4 sheets.
Here are two sets nested to fit 5x10 sheet.
StumpFAB
Post by StumpFAB »
The original file was missing one of the comer “legs”, fyi.
StumpFAB wrote: Sat Dec 11, 2021 8:49 pm The original file was missing one of the comer “legs”, fyi.
OK - Thanks for pointing that out. I looks like there is still plenty of room to add 2 more of the legs to the nest.
Mccheezin
Post by Mccheezin »
I scaled the original one that I cut down. Cut this one out for one of my bosses today. Came out just over 3ft tall. At this I also combined the side pieces with the upper parts of tank so that it could just be formed instead of another weld joint. Just sheared the bottom to fit. With no bottoms on drawing you can easily get 4 of these out of a 4x8 sheet.
Great job! Very nicely done. And I am very envious of that nice stash of sheet metal in the background - wish I had that in my shop. Keep up the great work.
popafink
Post by popafink »
Mccheezin wrote: Wed Dec 22, 2021 6:01 pm I scaled the original one that I cut down. Cut this one out for one of my bosses today. Came out just over 3ft tall. At this I also combined the side pieces with the upper parts of tank so that it could just be formed instead of another weld joint. Just sheared the bottom to fit. With no bottoms on drawing you can easily get 4 of these out of a 4x8 sheet.
Can you share the smaller file please??
jwalk112
Post by jwalk112 »
First post here. Thought id share what i made off this file. I scaled it down to use about half a sheet. first burn was okay. Welds did leak at the corners after i added the legs. Have to fix that. Thanks for the ideas and file.
:Like :Like :Like :Like :Like
pouliny
Post by pouliny »
I'm Sorry I still can not find any files for theses
Is anybody willing to share?
tinspark
Post by tinspark »
pouliny wrote: Mon Jan 10, 2022 9:57 am I'm Sorry I still can not find any files for theses
On page 1 of this thread someone posted DXF files for a smudge pot.
Be sure you are logged in so that they appear.
Doug,
Hypertherm 45XP-
djreiswig
Post by djreiswig »
tinspark
Post by tinspark »
I wonder if this would work shrunk down to a table top version. Like a 2"x2", or a 3" x 3" stack with a small tank, say, 8" sq. or 10" sq?
I would never use one of the normal sized smudge pots around my place, but a dinky one might be cool to fire up once in a while at the lake or somewhere else. I would fire it up the first time away from the house and combustibles if i were to ever fab a dinker.. It sounds interesting.
Also, I grew up around grape farmers and a lot of them used them. They were all lighter gauge than I am seeing on this thread
Doug,
Hypertherm 45XP-
These are the ones I remember seeing when I was younger. Back in the 50's they used these around road construction along with the barricades - long before they had the modern ones with the batteries and flashing lights.
airdy
Post by airdy »
Very Cool
Aird
Ponderosa Forge
Sk. Cdn.
HammerDownJustin
Post by HammerDownJustin »
mitchw123456 wrote: Wed Dec 08, 2021 12:56 pm
StumpFAB wrote: Tue Nov 30, 2021 5:52 pm 1DAB1ABA-13E5-406D-9C9A-5A253C4155B1.jpeg
I’ve cut a couple of these from these files, has anyone had to add the outer pipe that is normally on these smudge pots to get them to work, or do they work well without them? I know I have to add an adjustable carburetor of sorts on the fill port, but every smudgepot I’ve seen has an external pipe that 90’s back into the chimney higher up.
I haven’t lit one up yet, but getting close.
The return pipe recirculates the unburned fuel. Helps keep it from smoking as much.
i know with the one I built (different design) i tried it both ways and it gets much MUCH hotter with the return pipe.
Miller 251 Mig
HammerDownJustin
tinspark wrote: Tue Jan 11, 2022 4:54 pm I wonder if this would work shrunk down to a table top version. Like a 2"x2", or a 3" x 3" stack with a small tank, say, 8" sq. or 10" sq?
New a guy that was making a table top version. Only issue he had was didn't put off near as much heat. But bet it would be cool on a table top outside when lounging around.
Miller 251 Mig
HammerDownJustin
I have orchid style and they are great.
Miller 251 Mig
Blunt750
Post by Blunt750 »
Finally got my pot welded up and put for a test run. What are some type of fuel you all use?
tinspark
Post by tinspark »
Blunt750 wrote: Fri Jan 28, 2022 10:07 am Finally got my pot welded up and put for a test run. What are some type of fuel you all use?
I haven't built one yet, but I believe they can be used with diesel and a variety of different liquids, including kerosene, and cooking oil.
Maybe do a test run somewhere safe with a hose and fire extinguisher handy..
Thats what I am going to do if I build a mini smudge pot.
https://smudgepotdirect.com/
Doug,
Hypertherm 45XP-
DieselFumes
Post by DieselFumes »
Man these are cool! That's some big flames, they must burn up a lot of fuel?
ROKCRLER
Post by ROKCRLER »
Here's two I made based off the shared files.
This one turned out a tad big due to all the details cut into it.
This was the first one 36" tall stack.
Next ones will be a different style stack, im not too keen on the square stack.
4x8 Dynatorch
PM85
~Mo~
