Mach 3 settings
Re: Mach 3 settings
That worked now my torch won't fire
Re: Mach 3 settings
YOu need to setup the pin for output #1 most are pin 9 (from robert's info you may need to use pin 14 not 9) when you set it up you can hit the F5 key when on the program page if correct it will fire the torch but hit it again to turn off fast. The first page below sets it so M3 will fire the torch from G-code and m5 for off.
Re: Mach 3 settings
Thank you guys for everything finally got to cut something today!
Re: Mach 3 settings
Beautiful. Happy to be able to help.
Re: Mach 3 settings
Happy to help, bet you learned a few things along the way, funny how problems do that
And saved some bullets I'm about to pull out my 45 and fix it my way!!
Thanks for the reply
