Happy Halloween
- edclayton1
Re: Happy Halloween
Thanks for sharing the file. It's awesome and cut out perfect. Can't wait til my LED's get here for it.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
Re: Happy Halloween
Awesome share, thank you!
Re: Happy Halloween
I'm also a little confused on the color change throughout the led's. How are you changing them in different areas? Are you cutting the strip and crossing wires?
- Peechy
Re: Happy Halloween
You bet crossin wires
Re: Happy Halloween
Nice and thanks!
Re: Happy Halloween
One look and my wife said that she wanted one so I just powder coated it and didn't worry about the lights, she loves it.
Thank you for the share, it cut great.
- Peechy
Re: Happy Halloween
wicked !
Re: Happy Halloween
DWalls,
I started powder coating a few months ago and so far, even being a novice, I feel that my results are pretty good. However, I've only tackled single color jobs. Could you offer any tips on how you did this piece utilizing 3 different colors? It looks really nice. I was considering powder coating the entire piece black and then painting the orange words and the white ghost with spray paint. Not sure how well the spray paint would stick to the powder coat under it though.
Thanks in advance for any tips!
LDR 4'x4' Water Table
Command CNC Linux Controller
Plate Marker
Power Max 45xp w/ Machine Torch & Hand Torch
2 Stage filter, Motorguard filter & HF Ref Dryer
InkScape / SheetCam
Plate Marker
InkScape / SheetCam
Re: Happy Halloween
Never powder coated, but my guess would be to do it similar to how you would paint it. Powder and bake one color, then mask and powder successive colors.
I'm not sure how layering powder works. If you should do the whole thing in a base color and then layer the other colors. That's how I paint so I don't have bare spots where the colors meet.
Re: Happy Halloween
I have done allot of the yeti cups, some with 2 and some with 3 colors on them. On this item I sprayed the orange on the words then sprayed the white on the ghost and pointed the gun in the opposite direction so that I wouldn't get the colors mixed. I then used my small vacuum with a small brush to go over and pick up any of the overspray that was on the large part. I then baked it for about 60 to 75% of the cook time of that powder, let it cool then taped it off with blue painters tape and sprayed the large part black. I then put it in the oven for about 1 to 1.5 minutes then took it out and peeled the tape off and cleaned off the glue residue from the tape, if you cook it full time with the tape on it then it is harder to get off, then cooked it to time called for which was 20 minutes.
I learned allot about powder coating from Mancrafting on youtube he did allot of powder coating on the Yeti tumblers and you can use all of the same techniques on the steel that we cut now.
Hope this helps.
Hope this helps.
Re: Happy Halloween
Wife loved it. Thanks for sharing
Re: Happy Halloween
Thank you for the file.
Re: Happy Halloween
Thank you for sharing!
- Rem300wm
Re: Happy Halloween
Hello to All
Thank you for sharing the file.
Rem
Rem
