Jeep Grill Firepit DXF Design
InsaneCreations
Re: Jeep Grill Firepit
Post by InsaneCreations »
MPN Signs wrote: Tue Nov 06, 2018 3:07 am What are the names of the pins or where can I get them?
Linch pins
Harbor frieght has them for cheap
Home Depot, tractor supply are other options
MPN Signs
Post by MPN Signs »
Thank you for the info!
reklez2010
Post by reklez2010 »
Looks Great! Thanks for the share
racecar366
Post by racecar366 »
Sorry new to all this . We have a table on the way and just trying to get some stuff to cut and mess when when we get it in . What design program can i up load this to to change or put a name on it to cut ? I tried incscape and none of these files will upload to it . I have got other dxf files to load just not any of these. Thanks for any and all help
racecar366 wrote: Sat Jan 05, 2019 1:51 pm Sorry new to all this . We have a table on the way and just trying to get some stuff to cut and mess when when we get it in . What design program can i up load this to to change or put a name on it to cut ? I tried incscape and none of these files will upload to it . I have got other dxf files to load just not any of these. Thanks for any and all help
The original file was a pcm but there is a dxf version posted also. Try this one and see if it works
jeep2007-2018.zip
racecar366
I tried every file that was posted so I don’t know . Other dxf files work from other projects just not this one. No clue lol. Thanks
Kfab
Post by Kfab »
How much are you getting for the jeep fire pits?
Alabass
Post by Alabass »
Kfab wrote: Fri Jan 18, 2019 2:02 pm How much are you getting for the jeep fire pits?
I'd like to know this too. I had a customer request one of these made out of 1/4" steel and 3'x3'. (meaning the flared ends would be 40" wide). It's going to take about 1&1/2 sheets of steel and will weigh over 300lbs. They also want it all welded out, not pinned together. Based on the cut calculator, I'm looking at charging about $950.
BackwoodsLaser
Post by BackwoodsLaser »
That looks awesome.
sagreen83
Post by sagreen83 »
I sell a few here and there and get $250 for them using the original size our of 3/16" steel, cut down to 19" long on the sides.
Alabass
Post by Alabass »
Here's the beast made from 1/4" plate. 40" wide at the "headlights", 35" long on the sides. All welded together and painted with high-heat paint except for the grill plate.
Alabass wrote: Tue Apr 02, 2019 9:50 am Here's the beast made from 1/4" plate. 40" wide at the "headlights", 35" long on the sides. All welded together and painted with high-heat paint except for the grill plate.
BEEFY :shock:
MAYHEMGARAGE
Post by MAYHEMGARAGE »
Definitely a must have for my yard! Thank you for the shared file!
ForceDesigns
Post by ForceDesigns »
I know that this one has been remixed and such a lot, but figured I'd throw my version up here since it is a public file. I made it so that the grill grate could be added or removed after it had all been assembled. No bent sides. Wide enough to fit in a harbor freight brake for the grill grate. 3D modeled it in solidworks from the ground up with the original as just inspiration. I make all of my fire pits from 10 ga, so that is what this file is setup for. Makes it fairly easy to move around but still hold up to the heat. Good ratio.
It won't let me attach the step file. But I have it if anyone needs it. No SVG.
jeep_side_js.DXF
jeep_grill_js.DXF
jeep_end_js.DXF
jeep_bottom_js.DXF
Home Built 4x4 CNC Plasma Table
Ethernet Smoothstepper
C25 BOB
MiniTHC
Hypertherm Powermax 45XP
Software: Mach3 and Sheetcam, Solidworks 2019 for serious design work and Inkscape for signs
Rough-n-Ready
Post by Rough-n-Ready »
ForceDesigns wrote: Mon May 20, 2019 10:16 am I know that this one has been remixed and such a lot, but figured I'd throw my version up here since it is a public file. I made it so that the grill grate could be added or removed after it had all been assembled. No bent sides. Wide enough to fit in a harbor freight brake for the grill grate. 3D modeled it in solidworks from the ground up with the original as just inspiration.
Looks great. What gauge steel you use?
Edit:
I noticed the bend in the grill in your photo looks off from what's shown in the design. Is this because the steel bent at the slot instead of the middle of the brake? Or did you do that intentionally?
Do you think trying to put it less far in the break would make it not bend at the slot?
ForceDesigns
I had trouble with the bend. Lol. I actually had the tooling at about 1" past the slot. But my swag brake bent it there anyway. I need some more shallow angle iron to put in my brake so that it isn't as deep. Perhaps even a few pieces of angle. Just part of the learning curve. I don't use my swag press brake very frequently, need to find more projects for it.
I use 10 ga for all of my pits.
C25 BOB
MiniTHC
dannyg1
Post by dannyg1 »
Cut this out today . The file cut great but the grill without the legs is not needed. NEED to cut the grill with the legs 2 times and the side with legs 2 times. the side without legs don't cut nor the grill without legs.
_jay_
Post by _jay_ »
@ dannyg1
what file did are you talking about ?
There are so many iterations :)
The learning curve is exponential AKA "never ends " !
justfishmetalart
Post by justfishmetalart »
Thanks for the recent file and past files in this thread. Can't wait to cut! Fathers Day gifts will be needed soon!
DieselFumes
Post by DieselFumes »
Great mod! Thanks for the share ForceDesigns :Like :Like
idahogrizzly
Post by idahogrizzly »
Very Cool! Thanks for sharing!!
jocon57
Post by jocon57 »
thanks
shake
Post by shake »
Thanks for posting :-)
SkinnyPedal
Post by SkinnyPedal »
SierraBrad
Post by SierraBrad »
Would anyone have this design with the 19" sides 3/16" plate that they would share? DXF?
4x4 CNC Table running Flashcut
Thermal Dynamics A60i
Hypertherm 45
Millermatic 211
Millermatic 251
