It is currently Sun Jul 15, 2018 7:00 pm
Jeep Grill Firepit
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
shinertx
Re: Jeep Grill Firepit
Postby shinertx » Thu Jul 09, 2015 7:53 pm
Nice thanks for the file.
Plasmacam 4x4
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Plasma Creations
Postby Plasma Creations » Sun Jul 12, 2015 10:35 am
Thanks for the file
Diesel
Postby Diesel » Fri Jul 31, 2015 10:46 pm
I imported the .DXF into CorelDRAW, spent entirely too much time labeling all of the curves and organized it into outside/inside cuts in two separate layers.
This should make it easier for the SheetCam crowd. I tried to attach the relabeled .DXF as exported from CorelDRAW, but it was 5.5MB and too big for the forum.
Go easy on me, I'm learning. ;)
Cheers,
Matt
JeepFirepit_WithLabeledLayers.cdr
Custom LDR Motion Systems 5x10 table w/ rotary axis and scribe
Hypertherm Powermax85
Quincy 325 compressor
Ingersoll Rand D18IN refrigerated air dryer
Millermatic 251 MIG
Everlast PowerPro 256 TIG/stick/plasma w/ water cooler
muzza
Postby muzza » Fri Jul 31, 2015 10:58 pm
:? :? I'm not sure why you would do that.
There is no need for separate layers for sheet cam and if you've made the file so big you've done a lot wrong.
Murray
Diesel
Postby Diesel » Fri Jul 31, 2015 11:58 pm
I've been under the impression that you need to differentiate between inside contours from outside contours in SheetCam by selecting the proper layers:
As for the .DXF file size - I don't have a good explanation for that yet. :lol:
Cheers,
Matt
Millermatic 251 MIG
muzza
Postby muzza » Sat Aug 01, 2015 1:02 am
Typically if you have a closed object ie: something with a perimeter you select "outside offset" and Sheetcam will automatically offset inside cuts to the inside and outside cuts to the outside. If you are cutting something into an existing piece ie: a tree of life into a saw blade then you select "inside offset" and Sheetcam will automatically do the offsets correctly. On open paths ie: single cut lines you can choose to have no offset or inside/ outside offset. It will also automatically set the cut direction to what you have it set to (normally reverse direction) to keep the waste on the correct side of the cut.
Another setting you can change is whether to do all inside cuts first, then all outsides or complete each object first which is what I normally use, ie: on the jeep firepit one you would cut each piece before moving onto the next.
Murray
Diesel
Postby Diesel » Sat Aug 01, 2015 9:16 pm
Wow - OK...very good info there - thanks! I guess I shouldn't have taken the demo videos I've been watching too seriously.
While my table is being built, I've been trying to learn the software workflow the best that I can.
Cheers,
Matt
Millermatic 251 MIG
teammayhem666
Postby teammayhem666 » Sun Aug 02, 2015 10:58 am
that lokks amazing Wow! nice work
muzza
Postby muzza » Mon Aug 03, 2015 5:45 am
Sorry, I forgot to add that when you select inside or outside offset it also automatically puts the lead ins and lead outs if used to the correct side and set the cut path order to your preferences, if you wish to change the location or sequence you can.
1fine79
Postby 1fine79 » Wed Aug 12, 2015 10:27 am
Very creative, Dude. I love the fact that it is a knock down unit....that makes it very easy to pack up and take on a camping trip. Although, 3/16" material is still heavy to handle. Thanks for sharing.
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
d2day
Postby d2day » Wed Aug 19, 2015 5:16 pm
Thanks for sharing..that is an great piece of work.. :D
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
gene portable welding
Postby gene portable welding » Wed Aug 19, 2015 8:23 pm
thanks for file made one it's sweet
thermal dyn 152
4 x 8 eagle plasma table
400 amp portable welder
250 amp Lincoln stick
miller cp300 w/ S-52d
miller cp300 w/S54a setup for alum
13 x 60 south bend lathe
emco mill
Amer bender
http://www.facebook.com/gene'sweldingandfabrication :)
andoverbill72
Postby andoverbill72 » Sun Aug 23, 2015 7:18 pm
Hi, Love the Jeep fire pit. but I had to cut the tabs off because the slots were to small for the tabs. I welded it through the slot holes and then used a 80 grit sanding disc to finish it off. What do you think? I'm going to paint it with high heat paint tomorrow.
kevin53
Postby kevin53 » Fri Oct 02, 2015 11:41 am
I had to go back to page 8 to find this. I guess that is what search is for. another version of this that I made. I had a pallet of old tire chains that I used on the "tailgate" and modified the grill.
jeep firepit NO BOTTOM.dxf
ironhorse
Postby ironhorse » Wed Dec 30, 2015 2:03 pm
Fantastic idea
dr.dirty
Postby dr.dirty » Thu Jan 28, 2016 7:58 pm
Here is the one i made with a few slight changes.
chevybythesea
Postby chevybythesea » Sat Feb 27, 2016 12:23 pm
Question - how much do you guys charge for that Jeep grill?
5x10 TorchMate table (~10 years old, but new to me!)
http://www.thesteelyardinc.net
zj95
Postby zj95 » Thu Mar 17, 2016 10:35 pm
$150-500 depending on size and thickness
Holeski
Postby Holeski » Mon Apr 04, 2016 10:50 pm
I had started something like this, great work. Thanks
Scratch
Postby Scratch » Tue Apr 05, 2016 8:42 am
Awesome! Thanks for sharing!
soapcreek
Postby soapcreek » Wed Apr 06, 2016 5:44 pm
Thanks for the download.
Juniorchilli
Postby Juniorchilli » Mon Apr 18, 2016 4:34 pm
I'm new here on PlasmaSpider. Just wanted to say I love this Firepit! Great Job!
marcus_sho
Postby marcus_sho » Fri Apr 22, 2016 6:17 pm
Thanks for posting, great project.
jamveino
Postby jamveino » Fri Apr 29, 2016 3:50 am
First time sharer here. I wish I would have found this site before I put many hours in on my own Jeep Fire Pit. Here are a few different ones.
motoguy
Postby motoguy » Fri Apr 29, 2016 10:07 am
zj95 wrote:$150-500 depending on size and thickness
I cut one per original file size (approx 22" x 24"), out of 3/8. Using the sheetcam plasma calculator from another member, my "standard" price for this would be $150. That's straight off the table, only knocked off dross. Looking at some of the examples listed online, that seems to be quite inexpensive! The same unit, sold here:
http://www.thefirepitfactory.com/#!firepits/cjg9
Theirs is $418cdn as equipped like mine (floor, grill, feet), which is still $330 usd What am I missing here? Their flat rate shipping is an additional $109cdn.
Users browsing this forum: 2015cmax, cguethert, tkton and 8 guests
