Pipe/Tube Cutter
Pipe/Tube Cutter
Arclight Dynamics is going to be updating it's videos on using our pipe cutter! We are going to have video in our extensive library to help any and all with our pipe cutter knowledge. Stay posted!
- steel 35
Re: Pipe/Tube Cutter
I am waiting impatiently.
I would be more lost without your Videos:
Thank you.
Thank you.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- Gamelord
- 4.5 Star Member
That is awesome, can it be retrofitted to work on other tables?
- Capstone
I was wondering the same thing.Gamelord wrote:That is awesome, can it be retrofitted to work on other tables?
I watched the installation video and the execution is ingenious. The elimination of a chuck is a huge cost cutting engineering feat. I'd be very interested to hear from AD to see if they'd consider a "Plasma Spider" group buy as a kit for those people that think there's a good way to adapt it to their setup. Considering how many people here use the CandCNC Bladerunner controllers, the only issue I could see would be getting the MACH3 profile to work with tables that aren't already Arclight Dynamic's machine.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Great... I originally bought one of these when I purchased my table over 2 years ago and have never used it. Really looking forward to seeing the videos and getting it going. Most of my stuff is pretty simple but this will be a great addition as your videos helped me to really get going.
Supersweet
Every farmers kid in the midwest needs one of those. The kids here all have old Cummings trucks with bed stacks.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
I looked at the original video of the pipe cutter and I though it could be adapted to another table. It would need to have a alternate torch mount to that extended the torch to a position past the side of the table in the “Y” direction. Then a bracket for the pipe drive could be attached to the side of the table in the “X” direction and the a additional alternate “X” motor used to rotate the pipe. And the motor drive signals from the original “X” motor then switched to the alternate “X” pipe drive.
This would have the alternate “X” drive rotating the pipe and the “Y“ drive would move the torch to cut the pipe in the lengthwise direction.
But this may be my DIY mind running amuck
slight problem in my description the "Y" would rotate the pipe and the "X" would move the torch up and down the pipe.
I'm glad i'm not alone! I bought one as well. It is stored on the shop wall, and is still brand spankin' new! BRCcbassjr wrote:Great... I originally bought one of these when I purchased my table over 2 years ago and have never used it. Really looking forward to seeing the videos and getting it going. Most of my stuff is pretty simple but this will be a great addition as your videos helped me to really get going.
We can feel the anticipation for our new pipe cutting videos! The videos are currently being edited and will be here soon!
We have seen a few posts asking if we would assist/modify/support our pipe cutter on different plasma systems. Currently we do not have a pipe cutter that would be available for other tables. However, we have taken these suggestions into consideration and we thank you for the feedback!
Thanks for checkin' us out Arclight and Plasmaspider Family!
~drossmaker
~drossmaker
- steel 35
Fire the editor!
Fire the editor!
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
For educational reasons only, i would suggest posting the file of the flamed stack so we can calibrate our learned principles.
Brew Worx.
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
- Capstone
So I'll take that challenge. How does one go about buying these cutters separately from your tables?? laterally adapting mechanical engineering is so much fun.drossmaker wrote:We have seen a few posts asking if we would assist/modify/support our pipe cutter on different plasma systems. Currently we do not have a pipe cutter that would be available for other tables.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
Has anyone else cut a tube yet with the flame pattern. I would like to see if anyone could share a file to get started with.
That example fro Drossmaster would look great on BBQ grill
Brew Worx.
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
