need help!
need help!
hi all, i am having problems with a file that i am trying to burn... i have a 60x120 Pegasus Kaliburn PROLINE 2200. any help would be great!
Re: need help!
any info will help us to.
What kind of problem.
first off I downloaded it and it will not display in sheetcam!!!
Re: need help!
Im not happy with the "dots" on the edges within the drop out areas.
Re: need help!
There is nothing there when I try to open it.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
Re: need help!
It is a cad dxf. I created it with draftsite.
Re: need help!
If you are talking about the dots you need to change to inside offsets in SheetCam you are cutting on the line so there is no lead in to put the pierce in the waste.
Re: need help!
Try some different lead in and lead out types and try some different start locations location. These may all be modified in Sheetcam. You should be able to arrive at a good setup.
