Opening dxf files in Coreldraw x3
OTHill
Post by OTHill »
Hi. I'm having intermitant problems opening dxf files from this site. I can always open them in Sheetcam.But some of them won't open in CD x3,the latest one being A Valentines Share.Any suggestions?
Team Tracker
Re: Opening dxf files in Coreldraw x3
Post by Team Tracker »
What happens when you open the file? Do you get an error, do you just not see anything?
1-800-590-7804
SignTorch Vector Art
Post by SignTorch Vector Art »
X3 came out in 2006, and at the top of that DXF file you will see
9
$ACADVER
1
AC1021
AC1021 means AutoCAD 2007/2008/2009
X3 probably doesn't recognize autocad versions after 2006
so, if you open the file in a text editor and change change AC1021 to AC1015
there is a good chance it will work, AC1015 is autocad 2000/ 2001/2002
there is usually no reason to save DXF files in those later versions, it's best to just save version 2000 (or earlier if splines are not desired)
OTHill
Post by OTHill »
Reid T wrote:What happens when you open the file? Do you get an error, do you just not see anything?
All it says is there was a problem reading the file.
OTHill
Post by OTHill »
SignTorch Vector Art wrote:X3 came out in 2006, and at the top of that DXF file you will see
9
$ACADVER
1
AC1021
You lost me a little.How would you open the file in a text editor? Thanks.
notepad is a text editor, open the file in notepad
OTHill
Post by OTHill »
SignTorch Vector Art wrote:notepad is a text editor, open the file in notepad
Ok.Thanks.Dumb me.
OTHill
Post by OTHill »
Thanks again it worked.
