It is currently Tue Jul 17, 2018 9:01 pm
Plasmacam Replacement Cutting Grate DXF File
plascutart
Postby plascutart » Tue Dec 15, 2009 8:39 am
Hi,
Has anyone got a dxf drawing for "the grate" (set of 16 slats) for the plasmacam DHC2 4x4 table.
I would prefer to cut my own as the freight to Australia is enormous.
thanks,
plascutart.
Wesley Nichols
New 4x4 PlasmaCam Table
Postby Wesley Nichols » Sun Dec 12, 2010 3:01 pm
......This is my first file sharing post, so hope this all works.... I just cut out a new table for my Plasma Cam. I made the bad mistake of waiting too long before I replaced it, and had some trouble getting my 14ga sheet to lay flat enough so I could cut it out.... that's how toasted my old table was. Anyways.... If you have a table like this one, I would recommend cutting out a new table before your old one gets too bad. Here's a few tips... and with the downloaded file, you should have a new table for the price of a 4x8 sheet of 14ga mild steel. Cheaper than new.
This is already converted to a cut path.... sorry... but the kerf width was set at 20 thou... If your tip's cutting close to the same, you should be good.
I ran 100 inches per minute with a Hypertherm 1000... 40amp fine cut tip..... did a beautiful job.
You will need 16 strips, they will all come out of one 4x8 sheet of 14ga IF you cut 12 pieces out diagonally, and then tack the top triangle onto the bottom traingle.. cut it out, then weld it as needed. You'll see what I mean.
Hope this works as good for you as it did for me.. I drew it up in the plasmacam program... so that's how you'll need to open it... it's not DXF.
plasma table replacement pieces.pcm
RobertJohnson
Re: Plasmacam Replacement Cutting Grate DXF File
Postby RobertJohnson » Wed Oct 02, 2013 5:29 pm
Thank you for sharing! ;)
SolarImages
Postby SolarImages » Mon Jan 11, 2016 7:32 pm
Any possibility of getting this in a DXF?
see&see
Postby see&see » Sun Apr 16, 2017 6:32 pm
Here's the 4x4 file in DXF..
PlasmaCam DHC2 4 x 4 & Sampson 510 Snap 'n Cut w/Safety Switch Interface Hypertherm 85 & 45XP
fabxshop1
Postby fabxshop1 » Thu Nov 16, 2017 2:00 pm
any dxf files for the 5x10?
thinwater
Postby thinwater » Sun Nov 26, 2017 12:35 pm
I downloaded the dXf file in this thread and added more points to it. I did not rotate it back into the angled position to make it fit on the sheet in the machine. I have re uploaded the file on this reply. It is my first upload of a dxf so I hope it works. I did not modify the size or shape of the part so it should still fit ok but make one and check first, your offset can change the fit a lot so check before making a bunch.
see&see
Postby see&see » Sun Nov 26, 2017 7:14 pm
Sampson-DXF.dxf
Sampson Grates DXF
Return to “PlasmaCam”
