Clear coat
M & N Steel CNC
Clear coat
Post by M & N Steel CNC »
Are their any single part, no mixing good clear coats out their that you like for your steel.
That will give almost the same result as Deltron 3000.
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
Craig
Re: Clear coat
Post by Craig »
I have been using Permalac (http://www.permalac.com/) for many years now with good results it comes in spray cans and 1 and 5 gallon cans. I have even used it on rusts and patinas with good results. Craig Johnson
Craig Johnson
M & N Steel CNC
Re: Clear coat
Thanks, Craig, Will try it.
Corel Draw X5
SheetCam
Baileigh Inc
Re: Clear coat
Post by Baileigh Inc »
Craig wrote:I have been using Permalac (http://www.permalac.com/) for many years now with good results it comes in spray cans and 1 and 5 gallon cans. I have even used it on rusts and patinas with good results. Craig Johnson
$27 a can? Holy cow....how long does a can last? Is there a cheaper solution?
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
oldsoulmetal
Re: Clear coat
Post by oldsoulmetal »
sculpt nouveau has a permalac alternate.... actually it is permalac rebranded.
it is call clear guard. comes in matt and gloss. been using it for 3 years mainly the matt as a way to cut my solvent dyes.
but we do spray all the brewery signs which have a rust patina on them.... good results.
