Lotus scroll work
Lotus scroll work
My wife wants me to make this for her, can anyone convert this for me ???
Re: Lotus scroll work
Try this.
Could not get the photo to upload.
Mike
Mike
- admin
- Site Admin
Wow. Good stuff Mike. Looks fantastic and I added a sample image for you.
Admin
Admin
Mquick - How'd ya do dat so fast!? You didn't use that photo - did you? Amazing!
Thanks for posting the pic. I never can get that to work. I drew the whole thing. I dont mind posting and helping and drawings. I use the site alot and give back when I can. I shifted the pattern so here is one the matches the Photo layout.
Mike
Mike
I officially appoint you as ?DA MAN?! That drawing took one heck of a lot of work and my hat is off to you!
Here is a simple fire screen frame I drew up so I know how much work is involved! The problem with it is there is so much warping resulting from the heat. I guess a guy could cut it one little seg at a time and allow for cooling.
Maybe someone will play with it and come up with a better idea?
- Loyd
Mike, I don't know how you do that so well....my hat is off to you. Great job!!
Loyd
Loyd
I should add I was going to use something to simulate rivets in all those the small holes, but never got around to it. Then attach fire screening across the frame. Maybe one day....?
- Loyd
That would look good. We use a type of rivet to attach our ID plates on our reels that would work great for that. They are called
drive screws. They have a type of knurl on them and you drill a pilot hole and drive them in with a hammer that would look really
good on that screen.
Loyd
http://www.mcmaster.com/#drive-screws/=5qyaer
Loyd
Thanks ALOT..... I cut it out tonight i was so excited...
- Loyd
Boy!, you didn't waste any time. That looks good......looks like some brownie points from the wife are in order............
Loyd
Loyd
Hi Lloyd - I can't find those drive screws. Can you be more specific as to exactly what they are called or what the stock number is ?
Great idea! Thanks
Great idea! Thanks
Loyd wrote:That would look good. We use a type of rivet to attach our ID plates on our reels that would work great for that. They are called
Loyd
- Loyd
This product matches all of your selections.
Part Number: 90081A144
$2.85 per Pack of 100
Nail Type
Easy-Drive
Easy-Drive Nail Type
For Sheet Metal, Plastic, and Plywood
Material
Steel
Finish/Coating
Zinc-Plated
Decimal Size
.140"
Number Size
No. 6
Head Type
Oval
Shank Type
Spiral
Head Diameter
.260"
Head Height
.103"
Recommended Hole Size (Drill No.)
.120" (31)
Length
1/4"
Box Quantity
100
Specifications Met
Not Rated
Note
Length is measured from under the head.
I think that one would look good on your design. You have a great idea there. McMaster-Carr has a great selection of screen also.
Loyd
Nail Type
Easy-Drive
Material
Steel
Finish/Coating
Zinc-Plated
Decimal Size
.140"
Number Size
No. 6
Head Type
Oval
Shank Type
Spiral
Head Diameter
.260"
Head Height
.103"
.120" (31)
Length
1/4"
Box Quantity
100
Specifications Met
Not Rated
Note
Loyd
Thanks for sharing what a great design
Fantastic work. Thankyou
great work MQUICK thank you!!!
