It is currently Thu Sep 20, 2018 6:52 am
Built a spray booth today!
Oldsarge
Postby Oldsarge » Sat Oct 20, 2012 11:17 pm
6x12 Home Built Table
Hypertherm PowerMax 85
Metal Arcs
Re: Built a spray booth today!
Postby Metal Arcs » Tue Nov 27, 2012 6:29 am
Wow, this is great. Are you working off a particular set of plans for this build?
Largemouthlou
Postby Largemouthlou » Thu Jan 31, 2013 7:53 am
Looks good.. You may have wanted to go a little wider though.. I used the white board from HD and that shit atracts powder as good as the parts!! LOL wondering how the drywall will do.. I made mine 4' wide..
What did you wind up with for a pc gun system?
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
Oldsarge
Postby Oldsarge » Thu Jan 31, 2013 12:44 pm
Craig
Postby Craig » Thu Jan 31, 2013 2:14 pm
Looks nice was thinking of making one myself. Craig Johnson
Craig Johnson
Capstone
Postby Capstone » Mon May 19, 2014 3:37 pm
If only I had the room, I'd be building this tomorrow. It's been more than a year since the OP. Would you change anything in the design? How has it been functioning?
Capstone
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
Oldsarge
Postby Oldsarge » Thu May 22, 2014 10:13 pm
I would go a bit bigger, and would give more thought to the fan/ventilation.... I'm doing a lot more powdercoating than I ever figured on, and the vent/fan/exhaust portion is critical..... I have a nice woodworking style dust collector that I'm thinking about adapting to the setup to make it more efficient!
Oldsarge
Gamelord
Postby Gamelord » Fri May 23, 2014 2:12 am
I made my spray booth myself as well. For ventilation I used these two items purchased from Home Depot.
This is an attic vent fan. Cost is 77 bucks complete. Mounts perfectly between 16" center studs.
http://www.homedepot.com/p/Master-Flow- ... /100073799
The next thing I got was air conditioner filter registers:
http://www.homedepot.com/p/SPEEDI-GRILL ... 542263-_-N
These work perfectly because you can install standard filters, they mount directly into 16" center studs and can be opened to change/clean the filters without tools or fuss. Cost 30 bucks (filters not included).
The fan is mounted on the back, the filters mounted on the inside. Works perfectly, catches about 80% of all powder in the filter, the rest hits the ground. I get nearly zero powder floating in the air outside of the booth and zero powder comes out of the backside fan.
Hope this helps.
shinertx
Postby shinertx » Fri Jan 23, 2015 12:11 pm
DO YOU PLANE ON MOUNTING FILTERS ON THE OUTSIDE OF THE FAN TO CATCH EXTRA POWDER THAT PASS THRU THE INTEIOR FILTERS SO IT IS NOT FLOATING AROUND IN YOUR SHOP.
Plasmacam 4x4
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
AnotherDano
Postby AnotherDano » Fri Jan 23, 2015 12:51 pm
If you slip a removable shelf just below the filters, you can increase the suction of the fans by reducing the intake air by decreasing the source area. Also, your flyby powder is easier to reach with a vacuum. For the bigger pieces, just remove the shelf.
Mine was made with what was available (free). These are shipping frames for Harleys. The dealership was going to just trash them.
The back wall was cut out for furnace filters and framed for a HF shopvac.
Dano Roberts
[email protected]
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
AIRFLOWKID
Postby AIRFLOWKID » Mon Dec 11, 2017 12:25 pm
AnotherDano, how did the shop ax work as far as controlling over spray powder?
WyoGreen
Postby WyoGreen » Mon Dec 11, 2017 9:59 pm
Dano is no longer with us, but I did buy his booth off his son. He ended up using a Grizzly 1 1/2 HP dust collector, and it works very well, I get next to no over spray on the powder.
CNC Router table
Return to “Powder Coat”
