The question: Can you resize all of the holes in a drawing simultaneously?
Resizing all holes in a drawing?
- Joe Jones
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
- Joe Jones
Re: Resizing all holes in a drawing?
Actually, I forgot about the ability to convert CUT PATHS to open and closed paths!
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- rdj357
As I said over on the owner community - well done. That's a great, outside the box trick! It will be less handy if you have many other holes in the drawing unless you spend some time grouping and moving things around but definitely something to tuck back and analyze which method would be faster, offset or this!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- Joe Jones
You are correct, Robert! If there are many holes of different sizes, you would have to GROUP the holes of the same size (using VIEW>SELECT>) in order to only change THOSE holes to a new size. Otherwise you would offset ALL holes (and other shapes, squares, stars, triangles, etc.) using the process in the video. Good call!rdj357 wrote: ↑Sat Mar 09, 2024 10:28 am As I said over on the owner community - well done. That's a great, outside the box trick! It will be less handy if you have many other holes in the drawing unless you spend some time grouping and moving things around but definitely something to tuck back and analyze which method would be faster, offset or this!
My assumption was that the holes were all for pop rivets, as the OP stated, so the process would work for THAT. But one must be careful not to resize ALL closed paths in a drawing.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- Joe Jones
A final comment on the process of resizing holes in a drawing...
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
