More 3D Metal Puzzles
More....
- elkriverfab
Re: More 3D Metal Puzzles
These look great!
Do you have any photos of the pieces put together?
Shawn.
Shawn.
- plasmajoe
Awesome!!! Thanks for sharing. Do you have pictures of these per chance?
Here are some pics that I pulled off internet...
I can't wait to cut these out!! Thank you! What is the best size to cut this at? Thank you agian!
WTFChuck
WTFChuck
I have the notches scaled down to .060" material. If you want bigger material, then scale accordingly. For example...if you want to use .119" material, then you would have to divide .119 by .060 (.119/.060)=1.98. You then would want to scale image in all directions by 1.98. If you want to use .25 plywood, then you would scale by 4.16.
The reason I use 16 ga material, is that we have a lot of drops of that size, and its free!!!
Should I post some more puzzles?
More....
awesome job thanks for sharing my kids are going to love these
-fitzy-
It ain't braggen if you can back it up!
- Chopper John
A Spider to add.
Chopper John
Mad City Cycles, Inc.
Hi John these puzzels are fenomenal thank you for these puzzels,do you have more or can you teach how to make them from the wooden templets you can buy.
I am very intrested to able to draw these puzzel.
Mossie
a newby
Mossie
a newby
Pic of last spider:
All these are great.
I could use the Buffalo Bison one if you have the DXF file for that one lol. Thank for all the files. They are awsome file. When I get a chance I would like to cut all of them.
Patrick
Patrick
Patrick
I love these puzzles,,,,
my problem, is with my torches i have a minimum of 30 amp torch, high definition and the kerf width is around .060 if i remember correctly.
The dragon puzzle for instance has corner reliefs in each slot that are only .020" dia. the math does not work and my controller destroys the part when it tres to send them over for cutting.
how do i fix this?
how do i fix this?
My Waterjet has this same issue as the Kurf is around .040". The small radius' confuse the system and when it tries to cut it, the cut is all blown out at that location. I solved my problem by doing straight point corners....just let the jet create the radius if that makes sense.
-Logan
-Logan
So i need to load and edit the file then to remove all those coner reliefs? im not very cad efficient.
also with the slot sizes and my kerf width i figure i have to scale it up just over 4 times, I then can use 1/4 material and the slots will be 1/4 in width.
Thanks for all the 3d files but my question is, how the hell does it all go together are the pieces numbered or is that something we have to figure out on our own !!!!!!!!
Hi, how to download?
- plasmajoe
You have to become a Contributing Member, you will then have your name changed to purple then download all you want.ckhong wrote:Hi, how to download?
Are there pictures of the Mammoth, Saber tooth, Pteranadon & F15 completed and if there are could you post them?
Thanks.
Thanks.
- Chopper John
This is a F15 I did awhile back. It's the only picture I can find right now but I will look some more.
Chopper John
- BrianMick
that raptor is awsome, I would love the file If you have itChopper John wrote:This is a F15 I did awhile back. It's the only picture I can find right now but I will look some more.
www.midwayiron.com
www.midwayiron.com
- Chopper John
Here you go Brian.
Reason: sample pic
Reason: sample pic
Chopper John
WOW thanks for sharing.
- BrianMick
Thank you for your postings! I've made a bunch of the puzzles that you posted on this forum. I did add a hour glass figure to the spider to make it a black widow, which is now perfect for Halloween! I'm curious do you have a 3-d puzzle of a praying mantis?
Thanks again to you and to everyone else on this forum who have helpled me!
