US Map/Flag with deer DXF
Here is a sign I made for the deer blind. Hope it works.
“A jack of all trades is a master of none, but often times better than a master of one.”
-Fusion 360
-Langmuir Crossfire table
-Fusion 360
Re: US Map/Flag with deer
Nice work!! Did you use Fusion 360 to draw this? I deleted the rectangle and closed in the letter "E".
Thanks for sharing your design.
Yes i did use fusion 360. It was a merge of several different files. That dashed rectangle is just a parameter outline for text. It only shows in the design, not the cut sequence. At least on my system. I have no idea how it opens up when you all download it.
-Fusion 360
-Fusion 360
This is how it looks when I open the file.
And this is how it would cut. The simplest thing would be to remove the rectangle. I'm sure that most folks will figure that out.Thanks,
Now that's awesome! Thanks Jhayes
Re: US Map/Flag with deer DXF
Awesome, thanks! Will change the year and cut for a buddy.
- jmersereau
jhayes,
Thanks for sharing your design. I updated it for 2024 and made a couple of minor adjustments.
Jim
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Nice Jim, your edits really finished it off, thanks for that. I made one small change to connect the inside of the 4 in 2024 to the main body. Attached is my edit, hope you don't mind.
- jmersereau
Plasmanewbie, thanks for catching that! I hate missing stupid mistakes.
PrimeWeld CUT60
plasmanewbie wrote: ↑Wed Mar 20, 2024 11:01 am Nice Jim, your edits really finished it off, thanks for that. I made one small change to connect the inside of the 4 in 2024 to the main body. Attached is my edit, hope you don't mind.
AmerFlag with Deer2024Rev2.dxf
AmerFlag with Deer2024Rev2.svg
Yep, my bad David. The original 4 was still on the screen behind my revised 4. I have deleted it and uploaded revised files. Getting older, eyes aren't what they used to be!
