I'm getting unwanted random straight cuts
JesseBaker
Post by JesseBaker »
I'm cutting some things on my plasma table and on one certain job I'm getting random straight line cuts. I'm using sheetcam and when I click on the "show rapids" they appear as blue lines with no assigned start #. Is there a way to delete these in sheetcam?
Re: I'm getting unwanted random straight cuts
You have the show rapids on see image.
So is the torch cutting during these rapid moves?
JesseBaker
It was on two of them. Neither of which had an assigned start point and (or) number.
JesseBaker wrote: Thu Nov 17, 2022 12:16 pm I'm cutting some things on my plasma table and on one certain job I'm getting random straight line cuts. I'm using sheetcam and when I click on the "show rapids" they appear as blue lines with no assigned start #. Is there a way to delete these in sheetcam?
What program did you create your problematic drawings with? Perhaps post the file (or one of them) that is giving you these random straight line cuts so we can have a look.
