FFA Future Farmers of America DXF
- RobinHillMachine
Not sure if I've shared this one here yet. FFA logo, simplified. DXF and SVG files.
Please post a picture if you cut it. I would love to see them. Thanks
Re: FFA Future Farmers of America DXF
Nice clean file!! Well done.
Very kool!!!
Nice! Thank you
- david jordan
thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
- 1/2 Star Elite Contributing Member
awesome! my daughter just started with the FFA in 6th
I am new here. How do you gain access to download this file? Amazing work!
Nice job Julie!
Thought I'd share one I did back in 3-2019 (Plasma cut 18" tall w/a little more detail) for a friends daughter to give
to her FFA Teacher at Poynette, Wi HS. I can't find the finished picture after powder coating and adding a backer!
I can post the file if anyone's interested!
That emblem looks awesome! @J-SIG I would love the DXF file for that if you can post it.
I'd love the file as well.
Thanks for your interest!
Here's the link to my new post!
https://www.plasmaspider.com/viewtopic.php?f=6&t=34577
Great job with lots of interest!J-SIG wrote: ↑Mon Nov 07, 2022 7:52 amThanks for your interest!
Thanks David!
I wish I had shared it before but Julie reminded me I had done it!
Gave this to a few FFA ones in the area to raise money!
Cut one out yesterday, looks good. Thanks for sharing.
Nice job! That one will look great detailed and painted - or other finish.
Thanks for sharing your work.
Thanks! I cut and donated to local FFA chapter. They got $285 for it.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
They have a file on the National FFA website to use, but so far I can only get gcode generated on sheetcam as it is a very heavy file. Here it is if anyone wants it. They post it for free.
North Pemiscot FFA
Wardell, MO
Langmuir Crossfire Pro
Hypertherm 45xp
Machine Torch
Wardell, MO
Hypertherm 45xp
Machine Torch
Similar to the trace I shared that I did in 2019!
Here's the link on here when I finally shared it!
Here is a picture of the file after I got it to cut. I added the Pemiscot County with Fusion and then had to import into SheetCam to get it to post process all of the cuts. I don't think I would cut this any thinner than 14 gauge, and maybe 11 if going outside.
North Pemiscot FFA
Wardell, MO
Hypertherm 45xp
Machine Torch
Wardell, MO
Hypertherm 45xp
Machine Torch
Nice Job! Looks Great!NPHS-FFA wrote: ↑Mon Mar 20, 2023 4:08 pm Here is a picture of the file after I got it to cut. I added the Pemiscot County with Fusion and then had to import into SheetCam to get it to post process all of the cuts. I don't think I would cut this any thinner than 14 gauge, and maybe 11 if going outside.
This is awesome, thank you for sharing.
I am an agricultural mechanics teacher and FFA advisor and will be using this for a few things round our shop and our greenhouse labs. Will post pictures when I am done.
Agricultural Mechanics Teacher, Southwestern Randolph High School, Asheboro, NC
Lincoln Torchmate 4400 with Linclon Flec Vut 85 on 3 Phase 480 Volt Power
Lincoln EDU Package
Lincoln EDU Package
You will definitely want to use sheetCam for the pathways. The file is huge and has overlaps. I tried for hours to get Fusion 360 to render it, but I couldn't get it to work right. I used Fusion 360 for the CAD work just not the CAM.
North Pemiscot FFA
Wardell, MO
Hypertherm 45xp
Machine Torch
Wardell, MO
Hypertherm 45xp
Machine Torch
Here is the straight file cut at only 22” tall.
Hynade Cut80 with a PTM80
14 gauge HR, 110 Ipm at 40 amps
North Pemiscot FFA
Wardell, MO
Hypertherm 45xp
Machine Torch
Wardell, MO
Hypertherm 45xp
Machine Torch
That looks great! Lots of detail and cut very nicely. Is that powder coat?
