This quick video will show you how to use the Ellipse tool and Shape tool to create arc's with a defined starting and ending point or freehand arc's.
Creating Arc's using the Ellipse Tool
Re: Creating Arc's using the Ellipse Tool
Justin - thanks for this new video. I tried it out and it works great! I will play around with it some more and let you know if I have any questions.
Justin - what is the simplest method to offset straight lines with CorelDraw? Say, for example I want to create a grid of line spaced 1" apart.
The quickest method I have found so far is to use the Parallel Drawing "Parallel LInes" tool.
The Parallel Drawing tool is new for CorelDRAW 2020 so I will do a quick video on other fast and easy techniques that can be used in any version of CorelDRAW
The Parallel Drawing tool is new for CorelDRAW 2020 so I will do a quick video on other fast and easy techniques that can be done in any version of Corel and see what you like better.
Have a look at this video viewtopic.php?f=225&t=34304 to see how this can be easily done without the Parallel Drawing tool.
Thanks Justin! I will have a look to see. I did try drawing a line and copy/past, then move the copy to side and put in the spacing in the dimension box at the top of the screen. I am interested to see how you do it.CorelDRAW for Plasma wrote: ↑Mon Aug 22, 2022 11:16 am The Parallel Drawing tool is new for CorelDRAW 2020 so I will do a quick video on other fast and easy techniques that can be done in any version of Corel and see what you like better.
