Sprocket file
Bently15
Sprocket file
Post by Bently15 »
I'm looking for a file to cut a 18 tooth 1" bore sprocket for a #40 chain, any help will be appreciated
Re: Sprocket file
Joe Jones
Re: Sprocket file
Post by Joe Jones »
Bently15 wrote: Mon Jun 20, 2022 7:51 am I'm looking for a file to cut a 18 tooth 1" bore sprocket for a #40 chain, any help will be appreciated
Is this what you need?
18 TOOTH GEAR.dxf
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Re: Sprocket file
acourtjester wrote: Mon Jun 20, 2022 9:11 am I have used this company for years
https://www.surpluscenter.com/Brands/Co ... 3-18-E.axd
Thanks for the great find Tom! I will most definitely bookmark this one for future reference.
SegoMan DeSigns
Re: Sprocket file
Post by SegoMan DeSigns »
They are the best, the majority of the press brake components came from them :Yay They have the best parts / breakdown of any company out there and it is only 2 day ground to get it to KommieRado
Re: Sprocket file
SegoMan DeSigns wrote: Mon Jun 20, 2022 6:23 pm They are the best, the majority of the press brake components came from them :Yay They have the best parts / breakdown of any company out there and it is only 2 day ground to get it to KommieRado
I'm glad to hear that! And fast shipping too.
Thanks for sharing your experience with them.
SegoMan DeSigns
Re: Sprocket file
adbuch wrote: Mon Jun 20, 2022 6:38 pm
Yeah I hate sites that take longer to look up the parts than order it, Surplus Center has the ever expanding tree you can select from. Now if I could only fix KommieRado back to where is was Pre-Kali :Sad
Joe Jones
Re: Sprocket file
Post by Joe Jones »
Wasn't the OP looking for a cut file for the sprocket?
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Re: Sprocket file
Joe Jones wrote: Tue Jun 21, 2022 10:12 am Wasn't the OP looking for a cut file for the sprocket?
That was my take on it. Looks like he got 2 options :Yay
Bently15
Re: Sprocket file
Post by Bently15 »
Joe Jones wrote: Mon Jun 20, 2022 11:22 am
18 TOOTH GEAR.dxf
Thanks so much i'll give it a try.
harrymorley
Re: Sprocket file
Post by harrymorley »
I use this site all the time..and its free
http://www.idleamusements.com/?page_id=367
Re: Sprocket file
harrymorley wrote: Wed Jun 22, 2022 1:59 pm I use this site all the time..and its free
Thanks Harry! That's another good source to have. I will most definitely bookmark it for future use.
jkesler89
Re: Sprocket file
Post by jkesler89 »
Can someone do a 52 tooth for a #40 chain?
Joe Jones
Re: Sprocket file
Post by Joe Jones »
What is the roller diameter and the pitch of the chain? .312" x .5", I assume.
You did not specify the shaft diameter, so you may need to change this.
52 tooth #40 sprocket.dxf
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
jkesler89
Re: Sprocket file
Post by jkesler89 »
Joe Jones wrote: Fri Aug 19, 2022 2:27 pm What is the roller diameter and the pitch of the chain? .312" x .5", I assume.
It worked perfect. I did scale the center hole to what i needed but, it its perfect. Thanks
Joe Jones
Re: Sprocket file
Post by Joe Jones »
jkesler89 wrote: Fri Aug 19, 2022 4:03 pm
I am glad I could help you.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Re: Sprocket file
This is a great resource as well. Thanks for that tip.
ROKCRLER
Re: Sprocket file
Post by ROKCRLER »
I ran across this site and thought you might like, i have not used it yet.
https://geardxf.software.informer.com/
4x8 Dynatorch
PM85
~Mo~
