help with file conversion on machine
Hi, im having trouble with a librecad drawing when i transfer it onto my machine. it comes through with a million pierce points, and kills the quality of the piece. Anyone know how to fix this? I appreciate any advice
Re: help with file conversion on machine
Post your dxf file and we will check it out. Also more details about you machine would be helpful. What software are you using to create the cut paths (g-code) and to run the machine?
I am drawing in librecad, and using Pronest to put on a flash drive. My machine uses phoenix. It's a hypertherm HT2000 hyspeed. micro edge controller. also, how do i upload my files here?
I didn't find any problems with your dxf file. I simply linked it to eliminate all the intersections. See if this one works for you.
Click on "Attachments", then "Add files" attach your files.
I count 163 pierce points after linking paths.allamericanfab wrote: ↑Thu Jul 22, 2021 12:51 pm Hi, im having trouble with a librecad drawing when i transfer it onto my machine. it comes through with a million pierce points, and kills the quality of the piece. Anyone know how to fix this? I appreciate any advice
got it to work. Thanks a bunch, i really appreciate the help!
You are welcome! Happy to help.
