Large Deer Scene
bwv1993
Re: Large Deer Scene
Post by bwv1993 »
Can anyone convert this file so it it is not one huge object? Ungroup it?
John Frantum
Post by John Frantum »
BVW1993, if you select the entire image and "explode" it, you should be able to move parts around or copy desired areas.
John Frantum
Here, I exploded it for you, but now it has about 6 million nodes:
Large Deer Scene Exploded.zip
techno
Post by techno »
Thanks for sharing.
Cottonwood Bottom
Post by Cottonwood Bottom »
Very nice Thanks for the share
mansfieldwelding
Post by mansfieldwelding »
thanks for the share
Jfile
Post by Jfile »
Very nice file. Thanks for sharing. Just curious what size you recommend for the finished cut so that all of the detail remains intact?
Thanks again for a great design.
LDR 4'x4' Water Table
Command CNC Linux Controller
InkScape / SheetCam
gslavik
Post by gslavik »
Nice work, Thank you for sharing!
gregory.osborn
Post by gregory.osborn »
Awesome File,Thank You
Searchman
Post by Searchman »
Beautiful Thanks
Metal Works
Post by Metal Works »
Thank you very nice
Dspinden
Post by Dspinden »
THANK YOU!
farmfab
Post by farmfab »
Thank you for the file it looks great.
JerryC
Post by JerryC »
Great, thanks
SRdesign
Post by SRdesign »
A customer wanted a mountain scene with deer and bears so i dug this one up and modified it. This will be wrapped around a bar with no backing so that is the reason for changing how it is cut. It cut well at its current 57.75 length x 22.5 height for the middle section. there was one unintended drop that happened in between the middle deer's legs but i went back and fixed that in the file.
mountain scene.dxf
mountain scene.svg
My 4x8 Build
DIY 4x8
C&CNC Bladerunner G5
Hypertherm PM85
Awesome edits to John's awesome original design. Well done and thanks for sharing that with us :Like :Like
805cnc
Post by 805cnc »
amazing thank you
KajunKowboy65
Post by KajunKowboy65 »
very nice!! Thank you Sir
justfishmetalart
Post by justfishmetalart »
Thanks for sharing!
John Frantum wrote: Wed Feb 13, 2019 6:23 am Here is a scene you might be able to use.
Large deer scene 2.dxf
Outstanding work! This looks really great and should come in handy for the future.
david47julie
Post by david47julie »
very nice, Thank you
Kaos
Post by Kaos »
Thank you!
4X8 Elihu / Hypertherm 45XP
Kaos - (in memory of K9)
shinertx
Post by shinertx »
Nice work.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Willdamnit
Post by Willdamnit »
Still getting some luv here in 2023 thanks for sharing.😁
fab-man
Post by fab-man »
This is great! Thanks for the design.
