Easy way to centre torch on bars/box
SeanP
Post by SeanP »
I have lost count the amount of different ways I have tried to get the torch centered on box or flat bar, this just came to me today, very easy as the bearing was 40mm od and the flat bar was 40, even on other sizes I can see it working well.
I do find zeroing in the centre of the part and same in sheetcam is the easiest.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
beefy
4.5 Star Member
4.5 Star Member
Re: Easy way to centre torch on bars/box
Post by beefy »
Hi Sean,
good one.
In my workshop I made myself a tiered rotating shelf rack. Each shelf level is choc-a-bloc with bits of round and square bar, hollow tube, old bearings, etc, etc (God knows how much that shelf set now weighs). I also collect lots of old bearings from work.
The amount of times these shelves/boxes of bits and bearings have came is useful makes me happy I've hoarded them all.
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Very clever! thanks Sean
