I started getting this warning recently. Table still cuts, but I'd like to clear it. Can someone provide some guidance?
Warning during Post
Re: Warning during Post
The pierce height in your tool definition is greater than the rapid clearance height (in Options->job options->material). If you increase the clearance height to be above the pierce height the warning will go away.
Dynatorch changed the way their machines work a few times over the years. It looks like you have an older machine. I have attached a post that should work. Open the attached zip file and save the contents to any convenient folder. Now run SheetCam and go to Options->machine->post processor. Click on the 'import post' button and open the file.
Never a complaint about customer service with SheetCam Les to the rescue again
Les,
I run a Langmuir Systems Crossfire Pro. Will that dynatorch file be compatible? I'm a novice. Thank you for the quick reply.
It would be best to contact Langmuir to see what post they recommend.
I ended up doing a firmware flash recommended by them which came with a different post processor. So far things are cutting well. Thanks for the support and Sheetcam...makes life so much less stressful.
