Newbiy's diy 4x4 table -Hobby Plaz 1000
bob49
Post by bob49 »
Here is my 4x4 table, It is a diy gantry and controler kit made by 757 customs, It's called a Hobby Plaz 1000. It came with controler and computer, gantry and wiring. the rest is my own design. I added a logitrol jog pendent. the kit was 2,000 bucks which was a great deal. All you need is a monitor,keyboard and plasma cutter, and build a table. It comes loaded with sheetcam and mach3. Check them out at 757 customs.com. hope you guys approve of my design. Bob
elkriverfab
Re: Newbiy's diy 4x4 table
Post by elkriverfab »
bob49,
Looks like a nice build.
Great job, how does it cut?
bob49
Post by bob49 »
It does an excellent job for a machine with no thc. that will be added soon.
bob49
Post by bob49 »
Mick40
Post by Mick40 »
How is the gantry driven, I assume Rack and Pinion? Would you mind showing more photos?
Mick
bob49
Post by bob49 »
yes rack and pinion. with a simple 3/8-16 leadscrew on z axis ...i will post more pics Bob
north shore fab
Post by north shore fab »
id like to see more pics of the shop. looks like a great size building.
ronsii
Post by ronsii »
Nice looking table and shop :) You should be able to make some great cuts with that setup, looks promising :)
What are the specs. on steppers ?
twicecustom
Post by twicecustom »
Looks good! I would add 1 thing to it, a small plate of steel to block sparks from hitting your computer, just as a deflector. It only takes 1 spark to make a mess of things..
Jack of all trades, Master of none.
Benjiman
bob49
Post by bob49 »
i thought i shielded it pretty well. top is way bigger than footprint of computer and cutting side is 100% blocked,but you are right only one spark will bring things to a halt.
