Has anyone tried this software out? Its $125 for the software.
https://deepnest.io/
Jim
Deepnest Nesting Software
- SegoMan DeSigns
Re: Deepnest Nesting Software
Hey Jim,
That is not a fixed amount (the $$ slider moves) Slide it to 0 and try it, if you like it then through him some $$$
I downloaded it and used it one time. I usually just nest it on plasmacam software since i rarely have a bunch to cut on a new sheet. But it works well and fairly quick.
My primary interest would be the ability to nest into a remnant sheet, vs a new one. Can you define the remnant sheet as the "sheet", and nest within it?TTMotorsports wrote:I downloaded it and used it one time. I usually just nest it on plasmacam software since i rarely have a bunch to cut on a new sheet. But it works well and fairly quick.
I haven't looked into it that much. BUT you can slide the price bar to $0.00 and download it. If you find it useful kick the designer some money.
downloaded it to try, works very well. You can draw a sheet size, offcut, remnant ect and import it as the sheet to use, and then nest into it. Excellent to try and worth paying for. The downside is that it only works on one layer of the dxf file. You need to open the nested dxf back into cad and set your layers for holes, inside and outside offsets.
I haven't used any 'paid for' nesting software so I cannot compare
