2x72 belt grinder for knife making
Re: 2x72 belt grinder for knife making
Good luck Iv joined that forum but from the uk so doing more research into motors more than anything at the moment
does some one have DXF files for D-Backing Plates?
This has been on my list to build for a long time.
Being as you have it in a 3d cad file already could you link to an iges file for the assembly?
We finally made some progress on this build. Too many projects going on all at once and this one was not at the top of the honey-do list.
I don’t mind sharing the 3D model, but the 4MB AutoCAD 3D file becomes a 36MB IGES file. I could probably shave some of that off by deleting the detailed motor from the file, but it will still be too big to attach to a post.
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, CommandCNC and SheetCAM
Click here for build post
Looking good! Can't wait to hear how much you like it.
I don't have all the answers but I do have a lot of opinions....
ShopSabre Sidekick 8 with water table
Hypertherm Powermax 85 w/machine and hand torches
IR 5hp 60 gal,+ 60 gallons of storage and aftercooler
Lincoln Square Wave 200
14x40 lathe
14x40 lathe
@simko thanks so much for posting. What did you cut it out of?
Most of the parts are 3/8" steel, but there are a few parts that are 1/4" and 1/8".
I would have posted the files here, but the 3D file was bigger than this forum would allow me to post.
Steve,
The 3d Model would be super handy to have. Could you possibly upload it to a public dropbox account?
Scott...
Scott...
See the link three posts back.. I uploaded it to that forum. Registration is free and no fee to download files:
Amazing file, I can't imagine the hours you put into this. The CAD drawing is our Achilles' heel
The grinders turned out awesome and run smooth as silk. I made a few changes to the drawings based on stuff we learned during the assembly and loaded them up on my build thread on Sayberosg.com.
http://sayberosg.com/forum/viewtopic.ph ... 3&start=10
WOW Sinko, those did turn out awesome! Impressive and thanks for sharing your drawings!
Thank you
- d2day
Thanks for the share, awesome project.
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
SheetCam
ArtCam 7.0
CNC Router
ULS Laser
Cut Shop Software
LCTHC
- cguethert
Anyone able to post a dxf file for this project?
Thanks for sharing this looks like a fun project.
I tried the little circles, no luck as the kerf just would not allow the circles to be cut, skipped right past them. At this point I have the base pieces cut and in place, Need to narrow the machine in to not have such an angle on the cuts. I found making the tabs .94 inches cut down on filing for the tabs fitting the slots, yet now I worry that I may need to be super careful when I weld that it stays true. Plus I need to work on my peck for holes, it pecked all the way through. Thank you for the design and time you put into this. I have a binder full of notes, and plans.
Hey there I am close to final assembly for you version of the sayber I was wondering if you had some ballpark measurements for the shims behind the wheels just to get me in the ball park so I'm not cussing and taking it apart and putting it back together more than I have too
Matt
Matt
Responded to your post on SayberOSG
The DXF is missing one hole at the top where the spacers go. The top has 4 holes. Easy enough to fix just letting you know. To be clearer the top of the motor mounting plates.
Hey Simko just downloaded the Rev4 files from sayberosg. Was curious if the build parts manifest for the dc1 applies for this and possibly do you have what hole that you tapped?
Where can I get link to buy a set of drawings? Thanks
Great Job!
is there a dxf file for this grinder?
