2x72 belt grinder for knife making
Prototypetom
Re: 2x72 belt grinder for knife making
Post by Prototypetom »
Good luck Iv joined that forum but from the uk so doing more research into motors more than anything at the moment
balde07
Post by balde07 »
does some one have DXF files for D-Backing Plates?
Thor
Post by Thor »
This has been on my list to build for a long time.
Being as you have it in a 3d cad file already could you link to an iges file for the assembly?
Simko
Post by Simko »
We finally made some progress on this build. Too many projects going on all at once and this one was not at the top of the honey-do list. :lol:
I don’t mind sharing the 3D model, but the 4MB AutoCAD 3D file becomes a 36MB IGES file. I could probably shave some of that off by deleting the detailed motor from the file, but it will still be too big to attach to a post.
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, CommandCNC and SheetCAM
Click here for build post
ScottF
Post by ScottF »
Looking good! Can't wait to hear how much you like it.
I don't have all the answers but I do have a lot of opinions....
ShopSabre Sidekick 8 with water table
Hypertherm Powermax 85 w/machine and hand torches
IR 5hp 60 gal,+ 60 gallons of storage and aftercooler
Lincoln Square Wave 200
14x40 lathe
Simko
Post by Simko »
I posted the latest 2D/3D files here:
http://sayberosg.com/forum/viewtopic.php?f=8&t=153
8-)
whiskeymike
Post by whiskeymike »
@simko thanks so much for posting. What did you cut it out of?
Simko
Post by Simko »
Most of the parts are 3/8" steel, but there are a few parts that are 1/4" and 1/8".
I would have posted the files here, but the 3D file was bigger than this forum would allow me to post.
sagreen83
Post by sagreen83 »
Steve,
The 3d Model would be super handy to have. Could you possibly upload it to a public dropbox account?
Scott...
Simko
Post by Simko »
See the link three posts back.. I uploaded it to that forum. Registration is free and no fee to download files:
phillipd
Post by phillipd »
Amazing file, I can't imagine the hours you put into this. The CAD drawing is our Achilles' heel
Simko
Post by Simko »
The grinders turned out awesome and run smooth as silk. I made a few changes to the drawings based on stuff we learned during the assembly and loaded them up on my build thread on Sayberosg.com.
http://sayberosg.com/forum/viewtopic.ph ... 3&start=10
WOW Sinko, those did turn out awesome! Impressive and thanks for sharing your drawings!
Coppercreek19
Post by Coppercreek19 »
Thank you
d2day
Post by d2day »
Thanks for the share, awesome project.
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
cguethert
Post by cguethert »
Anyone able to post a dxf file for this project?
greatriver64@yahoo.com
Post by greatriver64@yahoo.com »
Thanks for sharing this looks like a fun project.
Craig Rumble
Post by Craig Rumble »
I tried the little circles, no luck as the kerf just would not allow the circles to be cut, skipped right past them. At this point I have the base pieces cut and in place, Need to narrow the machine in to not have such an angle on the cuts. I found making the tabs .94 inches cut down on filing for the tabs fitting the slots, yet now I worry that I may need to be super careful when I weld that it stays true. Plus I need to work on my peck for holes, it pecked all the way through. Thank you for the design and time you put into this. I have a binder full of notes, and plans.
jeep.eater
Post by jeep.eater »
Hey there I am close to final assembly for you version of the sayber I was wondering if you had some ballpark measurements for the shims behind the wheels just to get me in the ball park so I'm not cussing and taking it apart and putting it back together more than I have too
Matt
Simko
Post by Simko »
Responded to your post on SayberOSG
Craig Rumble
The DXF is missing one hole at the top where the spacers go. The top has 4 holes. Easy enough to fix just letting you know. To be clearer the top of the motor mounting plates.
sxt15
Post by sxt15 »
Hey Simko just downloaded the Rev4 files from sayberosg. Was curious if the build parts manifest for the dc1 applies for this and possibly do you have what hole that you tapped?
Markthearc
Post by Markthearc »
Where can I get link to buy a set of drawings? Thanks
10ducks
Post by 10ducks »
Great Job!
TRFabworx
Post by TRFabworx »
is there a dxf file for this grinder?
