It is currently Sun Sep 23, 2018 12:28 pm
CNC Oxy / Fuel - Mach3 / Sheetcam
79Bronco
Postby 79Bronco » Sun Mar 12, 2017 1:11 pm
What post processors are you guys using? I set up a torch yesterday but I do not have a good functioning post to run it.
My plasma post touches off the work to find material height. That will not work with the oxy setup. I tried a few other posts that came with sheetcam but none seemed to function right. I am fine doing all manual z movements but I need a way to be able to move the Z up and down while running a program. Right now I can not make any manual Z adjustments while a program is running. I have a solenoid for the cut oxygen so I need the post to fire that as well.
East German
Re: CNC Oxy / Fuel - Mach3 / Sheetcam
Postby East German » Sun Mar 12, 2017 3:22 pm
Hello,
you can make a User Button Z Axis Up and another Button Down and a User LED fore Z Axis by Hand with Mach screen:
The Code Up Button:
If (GetUserLED(1316) = 1) Then
DoOEMButton (233)
Sleep ( 500)
DoOEMButton (234)
End if
The Code Down Button:
DoOEMButton (235)
Sleep ( 400)
DoOEMButton (236)
End If
This is my setting, the output is 500 or 400 ms high and a Relais set GND to the THC Up or Down Pin.
With the sleep Time Adjust the travel distance from Z Axis.
The Button have a Hotkey U and D fore Up and Down.
You can control with the keyboard or with the gamepad with keygrabber.
Works fine every years on my Machine!
A other way is a Switch fore Up and Down!
See the picture!
Regards Peter
Homemade CNC Plasma-Watertable with Mach 3
Triple Beast + Leadschine Drive
Hypertherm Powermax 85
Machine Torch + PriceCNC THC
Hypertherm Powermax 1100
Machine Torch + Proma THC
79Bronco
Postby 79Bronco » Tue Mar 14, 2017 9:17 pm
Thanks for the info, I've never played around with editing my Mach screens honestly I'm not even sure where to start with that. Is there a way to just use the Z in normal jog mode while running a program? That would be ideal then I can just set up a remote pendant since I was planning on doing that anyways.
East German
Postby East German » Wed Mar 15, 2017 2:21 am
Hello Bronco,
I can do that to you I'll send you the set file from Mach3.
If you are interested then I do it?!
Peter
East German
Postby East German » Wed Mar 15, 2017 3:03 am
It could look like that.
Is a quick try :D
Peter
79Bronco
Postby 79Bronco » Sat Mar 18, 2017 8:10 am
That is perfect! That button will work while a program is running?
East German
Postby East German » Sun Mar 19, 2017 2:33 am
Hello
Yes, it works. But hardware is also needed. I'll make a plan in the next few days.
Peter
East German
Postby East German » Tue Mar 21, 2017 2:37 am
Hello,
A second LPT port is the best.
See the config from Output and input.
And make a Bridge from Pin2 to 12 (THC Up) and Pin 3 to 13 ( THC Down) see the Pic
Or a cheap BOB and uses the relays
The set File and Bitmap sent a PM
Regards Peter
asuratman
Postby asuratman » Sat Jul 07, 2018 7:41 am
Hello Bronco,
I know this thread was long ago, your table hardware set up almost the same as mine. How about your table work ?
Users browsing this forum: No registered users and 6 guests
